BURNING OIL
Old Mar 24, 2006 | 11:29 AM
jmv38's Avatar
Default BURNING OIL
99 GS-R......
Im burning oil... i was driving with my friend behind me, he called me and told that i had a little bit of black smoke coming out of my exhaust. i checked my oil and i was down a little bit, i use mobil 1, and im thinking about adding some Lucas oil stabilizer to it... any other suggestions? all help is appreciated
Old Mar 24, 2006 | 11:36 AM
Lan's Avatar
Lan
Default Re: BURNING OIL (jmv38)
When was the last time you checked it. When your friend saw the smoke where you flooring the pedal? Honda's are notorious for burning oil. Sounds pretty normal to me.
Old Mar 24, 2006 | 11:37 AM
Speed94's Avatar
Default Re: BURNING OIL (Lan)
I burn oil too in my LS/Vtec
Old Mar 24, 2006 | 11:39 AM
jmv38's Avatar
i've owned the car for 3 weeks, its got 65k on it, still new to the whole honda thing. i knew that hondas produce soot, but not smoke, anyway, i dont wanna have to re-ring my pistons...
Old Mar 24, 2006 | 11:45 AM
Lan's Avatar
Lan
Just check your oil as often as you can remember. What you are experiencing is fairly normal, some burn more than others and it is going to depend on your driving habits as well. Do a compression test; that way you are sure your motor is strong. If your numbers are close to 200 across all 4 you'll know that your internals are in good shape.
Old Mar 24, 2006 | 11:54 AM
reno96teg's Avatar
this is a bit general, but..
black smoke means you're running rich.
blue smoke means you're burning oil.
white smoke (don't confuse this for regular vapor) means coolant is getting into the combustion chambers.
how many miles since the oil change? do you know? were you hitting VTEC when he saw the puffs of black smoke? that may account for them.
Old Mar 24, 2006 | 12:00 PM
WhoDoYouThink's Avatar
Default Re: (reno96teg)
you have GSR, when you drive in vtec and get up in the rpm's alot you will burn oil quicker than most other cars. I have a brand new motor and when i drive it hard alot I notice my oil goes away pretty damn quick. Nothing to worry about, just keep an eye on your oil all the time. I usually check mine a couple times a week.
Old Mar 24, 2006 | 04:05 PM
ck123's Avatar
where ccan you go get a compression test?
and how much do they cost?
Old Mar 24, 2006 | 04:08 PM
OliGSR's Avatar
Default Re: (ck123)
If it's the first time you've used Mobil 1 in the car it may consume initially and then go down with more use. You also might want to check the valve cover gasket or cam plug to see if you're losing any there.
Old Mar 24, 2006 | 08:59 PM
Speed94's Avatar
You can get a compression check at any shop. It doesn't take too long (30 minutes or so) or you could just buy the tool to do it yourself. Its fairly easy.
19integra94
Dec 26, 2008 01:51 PM
vtec8804
May 31, 2007 09:24 AM
peel17
Feb 1, 2005 11:28 AM
bubba your prison bitch
May 10, 2004 07:34 AM
StormShadow
Oct 5, 2001 12:49 PM
