Car Shutting Off Randomly
Old Mar 24, 2006 | 10:51 AM
BlkB16EK9's Avatar
Default Car Shutting Off Randomly
Well title says it all, I would be driving down the road/interstate and the car would just shut off, i pull over to the side, and try to restart it, the car actually restarts but then turns off right away, after bout a minute it starts back up like nothing happens. then be driving normaly agian and kaboom thing happens agian, ahh....stressing me out, um any help would be awesome, thanks.
Things I've Did so far:
1. replace battery
2. replacing Disributor Rotor (as this post is posted)
3. Replace Ground wires i could find
After i replaced the ground wires and battery it stoped for awhile, but like if i drive the car all day or for a long time it shuts off like alot, its not over heating...um....thats all i can think of right now.
Old Mar 24, 2006 | 11:43 AM
hatchi's Avatar
Default Re: Car Shutting Off Randomly (BlkB16EK9)
did you check main relay??
Old Mar 24, 2006 | 11:49 AM
DannyDeuce's Avatar
Default Re: Car Shutting Off Randomly (hatchi)
Sounds like the ignition switch.
Did you have that checked out?
DAN
Old Mar 24, 2006 | 12:13 PM
Perfectionist's Avatar
Ignition switch (watch the gauge cluster when it happens) or the ignitor/coil assembly.
Old Mar 24, 2006 | 12:17 PM
ZipTieGUy's Avatar
main relay, do you hear your fuel pump priming?
either that or your fuel pump about to die soon
Old Mar 25, 2006 | 12:05 AM
White95SiHB's Avatar
Default Re: Car Shutting Off Randomly (DannyDeuce)
I'm going along with Danny Deuce and Perfectionist.
I also would like to suggest that it may also be the ignition cylinder/tumbler thing. The ignition switch on my car was fine. I had removed it and put in another one, but the problem persisted, so I put back the original switch. Turns out the tumbler/cylinder thing had to be changed. Once that was done, the problem was solved.
Old Mar 27, 2006 | 07:11 PM
BlkB16EK9's Avatar
can i get like some prices for all the things that you guys listed? im really on a budget. thanks for the help though
Old Mar 27, 2006 | 07:21 PM
4dohs4mohoes's Avatar
Default Re: (BlkB16EK9)
Same problem happened to me, and it turned out being the fuel pump.
j3wman
Nov 26, 2014 01:50 AM
roc0487
May 26, 2012 03:45 PM
cummins327
Dec 23, 2011 10:26 PM
Elgrys.Mendez
Aug 4, 2011 04:30 PM
slammed em1
Apr 20, 2010 01:23 AM
