Water pump question...
Old Mar 24, 2006 | 10:43 AM
I3ooS710's Avatar
Default Water pump question...
Simple, but I'd like to hear from different opinions..
What are the possibilities of the water pump failing, yet keep spinning?
I've had an overheating problem. Changed the thermostat- didn't help. I also ran it around the block a few times w/o the thermostat. Still overheats. Got a new radiator, still overheats.
I disconnected the top radiator hose and started the car (semi warm/cold), and no coolant ran through yet my water pump pulley is still spinning (no timing belt/pulley cover).
Some say it's my headgasket.. But I want to change the water pump first to make sure since the only symptoms of a blown gasket that I'm getting is overheating. No white smoke, no oil/water mixture, no overflow of coolant.
I hope it's the waterpump..
SO.. What are the possibilities of the water pump failing, yet keep spinning?
TIA
Old Mar 24, 2006 | 01:38 PM
I3ooS710's Avatar
Default Re: Water pump question... (I3ooS710)
anyone?
Old Mar 24, 2006 | 02:40 PM
hAILO's Avatar
just do a leakdown, if your good, its not the headgasket
Old Mar 24, 2006 | 02:50 PM
aarjosmos's Avatar
Try A leak down test. If that passes go for the water pump, it can keep spinning and not work. if that doesn't work might have a cracked block or something like that
Old Mar 25, 2006 | 07:31 AM
clockworks's Avatar
I've heard of cases where the pump impeller fins have corroded and leaves the pump spinning but no coolant flow is being created. My coworker came from working on saturns and said it would occasionally happen. I've never seen it (on toyota's), but hey, it could happen.
Good luck,
Greg
Old Mar 25, 2006 | 07:15 PM
lobudgetr's Avatar
Default Re: Water pump question... (clockworks)
It happens, but usually when a water pump goes bad the water, coolant, whatever is in there will come leaking out of the hole in the waterpump.
DumaDA
Jun 25, 2011 12:50 PM
justint7121
Nov 21, 2010 09:46 PM
95DC2GS-R
Aug 12, 2009 05:23 AM
Mr_Moos
Jun 24, 2007 10:04 PM
Eyewitness
Aug 18, 2003 08:11 PM
