Valve keepers?
Swapping out springs and retainers. Apart from taking waayyy to long to do this, is there a way to seat the keepers into the valve stem (keepers have a ridge, valve stem has a groove)? I am looking for seurity in knowing that the are seated and won't pop out.
Referring to the picture, the valve on the right is my main concern. See how the keepers are sitting away from the valve stem (not the endgap between the keepers). Probably overreacting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si »</TD></TR><TR><TD CLASS="quote">just push up and down on the retainer a few times quickly with your compression tool and make sure theyre sitting flush.</TD></TR></TABLE>
Did exactly that and rotated the keepers 90*. Worked out fine.
I would like to give the engineer at Honda that designed this retaining system a BIG middle finger. I didn't get the hang of it until #12 or so.
Lots of lube, lots of muscle, and lots of patience is the key.
thanks for the response
Another way to do it is take a hard rubber tipped hammer,not a mallet; a very very light one, and tap your retainers gently, if you seated the keeper correctly nothing happens. If you see a retainer projecting towards your facel; 1) duck 2) you didnt install that one correctly.
EDIT: oh yead dont forget some eye protection
