Help No Power To Fuel Pump
Old Mar 24, 2006 | 06:38 AM
carbonlaced's Avatar
Default Help No Power To Fuel Pump
Ok, I took the engine out of my car over the winter and changed the Automatic engine harness I was using to a Manual engine harness. I also changed the entire floor harness in my car so I could have power windows. As of now I have a 98 EX (Canadian SI) engine harness, 97 (EX/SI) Dash Harness and a 98 (EX/SI) Floor harness. Now when I turn the key I get power to the ignition, I can turn the car over, I'm pretty sure its firing but haven't checked that yet. I hear the fuel pump relay click and then click off after a few seconds, but no activity at the fuel pump. I checked to see if there was any current and nothing. Is there one place I can run a wire directly from the fuel pump relay? or does anyone know where I should be looking.
Old Mar 24, 2006 | 06:41 AM
sicones's Avatar
Default Re: Help No Power To Fuel Pump (carbonlaced)
you can get the wire directly at the fuel pump and supply a +12 volts to it, make sure you are connecting it to the correct wire, not the ground wire, and make sure the ground wire is grounded
Old Mar 24, 2006 | 07:44 AM
Default Re: Help No Power To Fuel Pump (sicones)
Dont I need to wire in a relay ? If I run a power wire directly to the fuel pump
Old Mar 24, 2006 | 08:03 AM
snatch's Avatar
Yes, you should run some type of relay/switch setup.
Kind of follows a fuel pump kill switch idea.
Old Mar 25, 2006 | 08:50 AM
Integrator's Avatar
Default Re: Help No Power To Fuel Pump (******)
Make sure to double check all of your grounds in the engine bay. I think you may have missed one when installing the new harness.
Edit: Also the pump only powers for 2 seconds at first and then power is shut off from it. You will have to check for power while someone else turns the key.
Old Mar 29, 2006 | 04:32 PM
Default Re: Help No Power To Fuel Pump (Integrator)
Ok, No big deal, it was a bad ground wire at the fuel pump for some reason, after playing around with it I got it working, car started like a champ. Thanks for the help
ale5six1
Oct 24, 2012 04:53 PM
Thor777
Nov 27, 2011 07:07 PM
f20cmx5
10
Mar 24, 2011 05:11 PM
jaerikd
Oct 6, 2009 08:10 PM
