help with a b20 swap
alright well my transmission on my 1995 honda civic ex just spun a gear and stripped the teeth so thats ruined. so this i think is the best time to buy a new engine. i decided to go with a b20 but i see no threads for such a swap. so if you ladys can help and tell me what items ill need or if you can direct me to a helpful thread itll be greatly appreciated.
well I just did the exact swap on my 98 coupe.
You'll need:
1. long block
2. b series transmission
3. 94+ teg axles
4. p75 ecu
5. ls integra intake manifold 94+ teg
6. 94+ teg distributor
7. 94+ teg shift linkage
8. Not sure which brackets, but probably integra motor mount brackets, you'll have to investigate this
9. 94+ integra exhaust manifold
And probably various other things, I hope you live close to a dealership.
You'll need:
1. long block
3. 94+ teg axles
4. p75 ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burningwrek »</TD></TR><TR><TD CLASS="quote">well I just did the exact swap on my 98 coupe.
You'll need:
1. long block
3. 94+ teg axles
4. p75 ecu
yes this is correct, i believe that youi can use the 94+ integra mounts and you should be fine...if not Hasport.com has mounts for this swap....i think you can also use a P28 ECU...? Good luck!
You'll need:
1. long block
3. 94+ teg axles
4. p75 ecu
the p28 ecu is a vtec ecu, so I'm not sure if it will work. He does a b20vtec then it'd be ok. I just know for a fact that the p75 ecu, from an integra ls, will work correctly.
