my temp gauge stays on cold
Old Mar 23, 2006 | 09:13 PM
OneTyteEK9's Avatar
B A N N E D
Default my temp gauge stays on cold
Like the title says. I have a '99 si cluster and the temperater needle just stays on cold. i know the needles not broken because i change cluster. everything is also plugged in. i don't know what i need to replace or not. thanks for the help in advance guys
Old Mar 23, 2006 | 09:46 PM
btleier's Avatar
have you checked the wiring to the sensor? if there's no physical signs (cut, not connected, etc.).... throw a test light on it.
Old Mar 23, 2006 | 09:50 PM
hmongboyLS's Avatar
Default Re: my temp gauge stays on cold (OneTyteEK9)
check your engine coolant tempature sensor and see if it's sending signal. Have you checked the inside of your gauges? it could be a possible that it's not working properly.
Old Mar 23, 2006 | 10:09 PM
D16SohcVtec's Avatar
Could be that your thermostat is stuck open.
Randomnoob
Feb 10, 2019 02:13 PM
Salvatorie
Jan 16, 2012 06:51 PM
klinster
Sep 23, 2009 04:19 PM
NFRap1
Jan 8, 2009 08:17 PM
mortificationrock
Nov 15, 2008 10:14 PM
