clutch pedal height adjustment
Old Mar 23, 2006 | 09:00 PM
LANEVOIX's Avatar
Default clutch pedal height adjustment
i searched for any good write ups or pictures on how to step by step how to adjust the clutch pedal height.
If anyone could please post something to help me out...thanks
my clutch engages high...with some freeplay going up...plus the pedal touches the floor when i press on it to engage...
help anyone thanks
Old Mar 23, 2006 | 09:12 PM
LANEVOIX's Avatar
Default Re: clutch pedal height adjustment (jdmdingdong4u)
bump anyone
Old Mar 23, 2006 | 09:36 PM
LANEVOIX's Avatar
anyone???
Old Mar 23, 2006 | 09:47 PM
Sack Master's Avatar
There is a little 12mm nut on the rod going to the master cylinder from the pedal. Loosen that nut up and then you can turn the rod in or out to adjust the pedal. Unfortunatly every integra I've seen has some funky *** thing on the rod where it connects to the pedal and for some reason it makes the rod spin freely and you get no adjustment out of it. I've changed the master cylinder in a few tegs just for that reason.
If you can get the rod to spin and actually adjust the pedal height you'll be set. It only takes about 45 seconds to do the whole thing. Very easy.
Old Mar 23, 2006 | 10:54 PM
.one lane's Avatar
.likes trains
Default Re: clutch pedal height adjustment (Sack Master)
When you change the height of the clutch would you also be changing the ammount of free play the pedal has?
huckduck
21
Mar 25, 2015 11:49 PM
vinuneuro
Aug 2, 2007 02:56 PM
EG2Driver
Oct 2, 2006 05:12 PM
MechEng
Jul 16, 2005 12:06 AM
