Suspension & Brakes Theory, alignment, spring rates....
omni coilover help plz!!!!!
Old Mar 23, 2006 | 06:18 PM
accrd18's Avatar
Default omni coilover help plz!!!!!
ok. i have installed a set of Omni power coilovers on my 98 accord lx4dr and after i was done i made sure all hardware was properly tightened. I set the car on the ground and preloaded the springs. All collars have been locked/tightened (3 of them 2 top one on bottom). i took it for a test drive and it seems that for every bump in the road i hit (mostly manhole covers which is like a really small pothole) i hear this clunking sound like something is loose. The right side does this worse than the left. over smoother bumps, like gaps in bridges and so on it seems fine. Also when i come to a complete stop the weight seems to shift foward like normal then back but then foward again almost like a boat or something. any suggestions and help is appreaciated thnx in advace.
Old Mar 23, 2006 | 06:28 PM
alwaysoverkill's Avatar
Default Re: omni coilover help plz!!!!! (drivinaway367)
I just had simular problem with my Buddy Clubs, and heres what worked for me.
Tighten the nut on the top of teh coilovers
You've already tightened the collars, but hand tight or did you try a rubber mallet to get them alittle tighter
And what finally got rid of the clunk on my BC...Add more spring preload. It took about 1" of spring preload to rid the car of clunks on small bumps. Now my coilovers are as quiet as they will ever be since pillow-ball mounts make noise, but the clunk was gone as soon as I added even more spring preload
Hope it helps.
Old Mar 23, 2006 | 06:44 PM
accrd18's Avatar
Default Re: omni coilover help plz!!!!! (alwaysoverkill)
ok thats easy make me feel a lot better lol. you have to try really hard to turn that nut or what did u use, i tightened it as much as i could with a wrench. should i use a cheater, impact gun etC?
Old Mar 23, 2006 | 06:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drivinaway367 &raquo;</TD></TR><TR><TD CLASS="quote">ok thats easy make me feel a lot better lol. you have to try really hard to turn that nut or what did u use, i tightened it as much as i could with a wrench. should i use a cheater, impact gun etC?</TD></TR></TABLE>
Ya, nut on te top, i used an impact gun to get it tight. Mine was somewhat loose
Old Mar 23, 2006 | 07:11 PM
accrd18's Avatar
sweet ill c if that works. I turned it as much as i could with a wrench, Got it about an inch below being flush with the bolt. how far down is yours?
vtec29k
Apr 16, 2012 09:24 PM
djdc87
Suspension & Brakes
Nov 24, 2008 08:14 PM
GS-R Power
Jul 27, 2006 02:43 PM
smR_lsvtec
Honda S2000
25
Dec 23, 2005 10:46 AM
trickmaster505
Feb 2, 2005 02:37 PM
