Honda S2000 Honda S2000
coilover problem need help!
Old Dec 21, 2005 | 08:06 AM
smR_lsvtec's Avatar
Default coilover problem need help!
just installed my Megan Racing dampers and i got it sitting on the tires all around so it isnt to low but the rear sounds like it is bottoming out. i lowered the dampers from the single perche so i dunno what went wrong. anything will help thanks in advance.
Old Dec 21, 2005 | 08:19 AM
Francesco's Avatar
Default Re: coilover problem need help! (smR_lsvtec)
so the rear tire is hitting the fender or it sounds like the coilover itself is bad?
Old Dec 21, 2005 | 08:50 AM
papa5murf's Avatar
is the coilover bottoming out?? or is it rubbing.. two complete differnt things...
if the coilover is bottoming out you adjusted them incorrectly...
Old Dec 21, 2005 | 08:52 AM
papa5murf's Avatar
Default Re: coilover problem need help! (papa5murf)
do you have a picture of the actual coilovers? so i can take a look at it? ... i'll be able to explain it to you better if i can see what the coilovers look like..
Old Dec 21, 2005 | 09:04 AM
Francesco's Avatar
megan coilovers are only 4 way adjustable. they are pretty much a re-labeled buddy club some say...
Old Dec 21, 2005 | 09:06 AM
Francesco's Avatar
Dylan...here they are on the s2ki group buy...
http://www.s2ki.com/forums/ind...37294
Old Dec 21, 2005 | 09:21 AM
papa5murf's Avatar
Default Re: coilover problem need help! (Francesco)
the dampening adjustability doesn't really have much to do with the coilovers actually bottoming out...
either way looking at this picture.....
there are three rings, you need to set up the preload on the spring section first... (the top two rings) once the spring is preloaded and set in place with the top two rings, then you loosen the bottom ring... then you twist the spring around to adjust the height... this will make the (black threaded piece) either go in the bottom housing or out of it... this will adjust the ride height...
Old Dec 21, 2005 | 09:25 AM
Francesco's Avatar
i have a feeling you might have messed the pre loads up...
most coilovers come out of the box pre adjusted, and if you dont know what your doing you can mess the pre loads up very bad...
i never touched the pre loads with my zeals, and they are still fine...
papa5murf's Avatar
if your shocks are bottoming out....the top is probably hitting your bump stops..(rubber)
look at this below picture.....
you want at least half an inch to an inch space between your bump stop, when the shock is compressed..... (this picture is of the shocks decompressed on a lift..)
Old Dec 21, 2005 | 09:30 AM
papa5murf's Avatar
if you are bottoming out the shocks... (metal to metal) you want to stop driving immediately... otherwise you will have blown shocks...
if you want to redo the preload on your springs....
lift them up.. using the top two rings... till the spring is barely secured... you should be able to touch it and move it slightly..(and i mean slightly) once you've done that tighten it up one revolution... then tighten the two rings and you should be set.... but keep in mind.. you want around half an inch to an inch of shaft showing when the shock is compressed.... so when the car is lowered you should see more then half an inch of shiny stuff..
to check how much space you have while the car is on jack stands.. is... get a hydro jack and put it under the brake and jack it up... allow the car to barely lift off the jack stand on that one side... a quarter of an inch will do and that'll show you what it'll look like when compressed..
Old Dec 21, 2005 | 12:04 PM
smR_lsvtec's Avatar
ok what if the spring is tight where their is no play what so ever can this cause it to bottom out?
Old Dec 21, 2005 | 12:45 PM
papa5murf's Avatar
Default Re: (smR_lsvtec)
the bottoming out would be depended on how much of the shaft you actually see beetween the bumpstop and the top of the shock...
Old Dec 21, 2005 | 12:49 PM
smR_lsvtec's Avatar
i have about 2in of shaft above the bump stop
Old Dec 21, 2005 | 12:50 PM
smR_lsvtec's Avatar
the bottoming out doesnt happen when im riding on the highway and hit a bump. you only can feel it when im driving very slowly and hit a little bump. like in a parking lot.
Old Dec 21, 2005 | 12:55 PM
smR_lsvtec's Avatar
correct me if im wrong the short coilover goes on the rear right? lol cause i know i didnt put them in backwards
Old Dec 21, 2005 | 12:58 PM
papa5murf's Avatar
humm.....
and yes.. the short one goes in the rear.. lol.. did you put them on the right side?
Old Dec 21, 2005 | 03:35 PM
smR_lsvtec's Avatar
haha yea i got the short ones in the rear
Old Dec 21, 2005 | 07:49 PM
Francesco's Avatar
Default Re: (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">humm.....
and yes.. the short one goes in the rear.. lol.. did you put them on the right side?</TD></TR></TABLE>
they might be univeral, left and right...
the teins arn't because they have the brake line brackets
Old Dec 22, 2005 | 03:56 AM
smR_lsvtec's Avatar
on the megan racings they dont have the brake line brkts. is anyone else riding on the Megan dampers?
Old Dec 22, 2005 | 04:16 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smR_lsvtec &raquo;</TD></TR><TR><TD CLASS="quote">on the megan racings they dont have the brake line brkts. is anyone else riding on the Megan dampers?</TD></TR></TABLE>
nah not to many people are running on them... they are ummm somewhat equivelent to apc (or at least their other products are..)
Old Dec 22, 2005 | 04:35 AM
smR_lsvtec's Avatar
i guess time for some new coilovers then aye. thanks for all the help papa5murf.
Old Dec 22, 2005 | 12:13 PM
granracing's Avatar
Sorry but have to ask, are you also using scales to corner weight the car?
When you are bottoming out, are you "just" hitting the bump stop? How low is your ride height? (I ended up cutting my bump stops in 1/2 to be able to achieve the ride height I wanted.)
Old Dec 23, 2005 | 05:25 AM
smR_lsvtec's Avatar
it doesnot sound like its hitting metal to metal so if i cut the bump stop will it stop hitting?
Old Dec 23, 2005 | 05:31 AM
papa5murf's Avatar
you want to re-preload the spring before you opt for cutting the bumpstop
Old Dec 23, 2005 | 06:53 AM
Enthalpy's Avatar
pre-loading the spring will reduce the amount of droop travel that the susp has and can cause inside wheels to lift un-necessarily in corners if you use too much of it.
