need help
Old Mar 23, 2006 | 05:59 PM
hashback's Avatar
Default need help
First time posting so bare with me...
Me and some friends just finished our first swap (d16z6 into 95 cx) everything went okay but when we try to hook up the battery sparks come out of a ground. A lot of people have told us that its a short to power or ground, but how do we fix it though? The ground that sparks is the one on the transmission. Any help would be very apreciated. T.I.A.
Old Mar 23, 2006 | 06:27 PM
92hatchling's Avatar
Default Re: need help (hashback)
heres a free bump cause i have no idea
Old Mar 23, 2006 | 07:02 PM
hashback's Avatar
Default Re: need help (92hatchling)
Thanks bump. Anyone
Old Mar 23, 2006 | 07:26 PM
BOOSTED RIVAL's Avatar
It might be the starter housing wire inside that it touching. My did the same until I check everything and I took off the starter and the positive wire inside the starter was touching the housing of the starter. Check that to see if the starter is the problem.
Old Mar 23, 2006 | 08:26 PM
hashback's Avatar
Default Re: need help (BOOSTED RIVIL)
Will do. That's probably it because everything else looks fine and has been checked multiple times; harness, battery, grounds, all that. Have to do it tommoroow but ill post results. Thanks
Old Mar 23, 2006 | 09:09 PM
hashback's Avatar
Will do. That's probably it, because everthing else has been double checked twice; harness, ground, battery, all that. Gonna try tommorrow. Will post results. Thanks
GoBrowns
Oct 3, 2013 02:56 AM
jdmeg6118
Dec 15, 2009 10:15 AM
bayoufrogg
Oct 24, 2006 08:18 PM
rex_racer728
24
Feb 3, 2006 10:57 AM
