TIMING HELP!!! WIERD SOUNDS ON LS-VTEC!!!!
Old Mar 23, 2006 | 05:27 PM
gsr dood's Avatar
Default TIMING HELP!!! WIERD SOUNDS ON LS-VTEC!!!!
ok i put a ls block to a gsr head....no check engine lights....but theres a reallllllllly bad sound coming from the valvetrain under load....like 2500rpm+....when my cam gears are at TDC....my crank pulley is off TDC by like 2or3mm would this cause the wierd shakin/chatter noise from the valvetrain????btw its about 2-3 mm retarded
Old Mar 23, 2006 | 06:35 PM
cdizzle14's Avatar
well then obviously the timing is off.At tdc on the crankpulley the cams should line up.everything ned to be perfect
Old Mar 23, 2006 | 07:47 PM
gsr dood's Avatar
Default Re: (cdizzle14)
thanks man....any other input?
Old Mar 23, 2006 | 08:01 PM
sikkkkktegra's Avatar
Default Re: (gsr dood)
yeah when putting on a vtec head on a ls block, it is ideal to use a vtec timing belt and a vtec waterpump...
Old Mar 23, 2006 | 08:13 PM
gsr dood's Avatar
Default Re: (sikkkkktegra)
yes i have the gsr belt and gsr water pump...its only retarded a little bit but i guess it has to be PERFECT ill be sure to check tommorow mornin wen i readjust that timing....ill post the news
Old Mar 23, 2006 | 10:21 PM
Sack Master's Avatar
2-3mm on the crank pulley wouldn't amount to anything noticable. We are probably talking less than 1/2 a degree. Most adjustable timing gears aren't even that close when set at 0*. You're problem probably lies elsewhere.
93egboosted
Mar 2, 2011 05:37 AM
IntegraMark
Sep 29, 2009 05:07 PM
Renegade
Feb 13, 2007 08:01 AM
gsr dood
Mar 24, 2006 01:58 PM
made in JAPAN
Oct 26, 2003 08:09 PM
