upgrading brakes on del sol
Old Mar 23, 2006 | 04:40 PM
tylonalsnifnfool's Avatar
Default upgrading brakes on del sol
I have read every brake topic in this section and found that different people give different info. I also did not see my specific question answered so I dont want a bunch of "used the search n00b" replys. So here it is:
I have a 1994 del sol Si. I need to know if I can upgrade to larger brakes from an integra WITHOUT switching knuckes. Its that simple. Just let me know my options (if any).
Thanx in advance.
One more question I saw mixed responses on:
Is my Si knuckle the same as a 92-95 Ex knuckle even though the brakes on the Ex are much larger?
Old Mar 23, 2006 | 06:18 PM
bump
Old Mar 23, 2006 | 06:34 PM
BlueIntegraBoy's Avatar
Default Re: upgrading brakes on del sol (tylonalsnifnfool)
use the search n00b
NAH NAH NAH
You would need to buy an Integra, 94-95 Civic Si/EX, or 94-97 Del Sol VTEC knuckle for an upgrade. They all use 10.25" rotors, but the Integra has a bigger caliper. Your knuckle and the EX knuckles are different.
OR
You can make custom caliper brackets to use on your knuckle and buy Integra rotors.
Old Mar 23, 2006 | 06:48 PM
OK thanx alot man. Is there any upgrade I can do with my stock knuckle?
Old Mar 23, 2006 | 07:50 PM
Default Re: (tylonalsnifnfool)
I believe there are companies that make big brake kits using your knuckle.
Wilwood makes a brake kit using 11" rotors...
http://www.wilwood.com/BrakeKi...x.asp
Black_Sol
Sep 3, 2007 06:44 AM
DelSolMarine
Aug 23, 2007 06:36 PM
asmallsol
Apr 16, 2004 06:13 AM
