Urathane bushing crunch?
Old Mar 23, 2006 | 03:39 PM
T-King's Avatar
Default Urathane bushing crunch?
I recently installed only 4 of my poly urathane bushings from the kit and I noticed they make noise. (whatever) I was wondering if i should just grease them or if theres something i can put around them to stop the crunching?
Old Mar 23, 2006 | 03:46 PM
HxClude's Avatar
Default Re: Urathane bushing crunch? (T-King)
you need to grease urethane bushings when you install them. some manufacturers also recommend that you regrease them once a year. noise is usually the result of not enough lubrication
Old Mar 23, 2006 | 03:47 PM
joeboxer212's Avatar
Default Re: Urathane bushing crunch? (HxClude)
I got the same problem. What's a good lube...WD40?
Old Mar 23, 2006 | 03:55 PM
britishlude's Avatar
Default Re: Urathane bushing crunch? (joeboxer212)
No mate, WD40 will just dry off quickly, you need preferably a thick grapphite based grease that lasts a lot longer, and will remain in place.
Old Mar 23, 2006 | 03:56 PM
HxClude's Avatar
a silicone-based grease would be a good idea. WD-40 is not a good idea. you'll need to at least loosen the joints where you have the bushings installed and shoot some grease in there with a grease gun and needle attachment (can pick those up cheap at Autozone). You really need to grease the bushings during assembly though.
Old Mar 23, 2006 | 03:57 PM
T-King's Avatar
Default Re: Urathane bushing crunch? (britishlude)
ok kool thanks man
Old Mar 23, 2006 | 06:16 PM
lude98SH's Avatar
Dont they make the black ones which are self greasing now ?
Old Mar 23, 2006 | 07:30 PM
M2B4's Avatar
Default Re: Urathane bushing crunch? (lude98SH)
yes they have the black ones that self grease them self
Old Mar 23, 2006 | 09:20 PM
Hawkze_2.3's Avatar
The black ones don't "self grease them self" or whatever, they are impregnated with graphite, so they make less noise.
WD-40 is a penetrating agent, not a lubricant. Use the grease that comes with your bushings or get some from Energy Suspension...
skyjumper_z
11
Feb 17, 2010 01:21 PM
kornerk12
Aug 8, 2008 06:21 PM
MadCityLude
Sep 26, 2006 11:01 AM
bg-33p
Jul 4, 2005 06:03 AM
MulletManRockStar
Apr 11, 2005 12:18 AM
