is it good to chip an ecu.
i was searching around and i see alot of chips for sale to raise the rev to 8500 on an ls. will that help by gaining horsepower also? i was also wondering what could i do to gain horsepower but yet have ti sound stock?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1ch1e »</TD></TR><TR><TD CLASS="quote">i was searching around and i see alot of chips for sale to raise the rev to 8500 on an ls. will that help by gaining horsepower also? i was also wondering what could i do to gain horsepower but yet have ti sound stock?</TD></TR></TABLE>
u should search more a chipped ECU is meant for cars that is modified and needs tuning if ur ls is stock dont bother, u wont make power up high anyways so raising the rev limit is useless unless
u should try getting aftermarket camshafts
Do not get a generic chip for your car. All it will do is decrease your gas milelage and increase the chance of breaking the engine.
Chipping an ecu and having it tuned on a dyno is fine.
There are cams out there for the ls head. Just gotta search. Crower makes a set for b18a and b18b heads. Be careful when intstalling cams because some need headwork so you don't get valve float/slap. This will also let you raise redline with a more agressive valve spring set-up in the head.
You could always swap the head and do an ls/vtec swap. Then you would have a lot more options on cams...
Internals would be the only way to keep stock sound and have more power.
Ported head/cams/higher compression pistons etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 »</TD></TR><TR><TD CLASS="quote">Do not get a generic chip for your car. All it will do is decrease your gas milelage and increase the chance of breaking the engine.
along the lines as to what I was going to say...
thanks for the help. i really appreciate it. i was watching best motoring and i think it was vtec something. they had a type r and the mechanic said it was vtec less and he took out the vtech to make room for bigger cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1ch1e »</TD></TR><TR><TD CLASS="quote">thanks for the help. i really appreciate it. i was watching best motoring and i think it was vtec something. they had a type r and the mechanic said it was vtec less and he took out the vtech to make room for bigger cams. </TD></TR></TABLE>
they make cams that dont have the vtec lobes anymore..
vtec is pointless on a track only car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickG »</TD></TR><TR><TD CLASS="quote">
vtec is pointless on a track only car</TD></TR></TABLE>
I have to agree with chubz0r on this one
as for a generic chip, all they do is give you a higer redline and richen your fuel mixture, they dont really improve power, and give you the option of revving a stock LS to 8400, things are bound to go wrong up that high, and you wont make power there anyways
Toda makes the VTEC Killer camshafts that eliminate VTEC.
http://www.todaracing.com/prod....html
As for the LS head, get a nice port/polish on the head, upgrade the valve-train, and throw in some nice Crower Cams. While you are at it, look into upgrading the bottom end with some higher compression pistons.
