Tranny question: checking condition before install
Old Mar 23, 2006 | 10:37 AM
Sparkles's Avatar
Default Tranny question: checking condition before install
I've got a 99 Si hydro tranny that I'm about to install. I was wondering if there was anything I can do to check the condition of the tranny while its out of the car. I'm hoping to find any problems before I spend the time installing this thing.
Old Mar 23, 2006 | 10:41 AM
unknown0001's Avatar
Default Re: Tranny question: checking condition before install (Sparkles)
Fill it up with tranny fluid, check for cracks/leaks on the case.
really you can't check the transmission without tracking the casing off and inspecting the gears/synchro's
your best bet is to just put in some new tranny fluid and hope you got a good tranny from a reputable person
Old Mar 23, 2006 | 10:46 AM
Sparkles's Avatar
Default Re: Tranny question: checking condition before install (Mr.RHTuner)
Cracking the case is no problem, the tranny is on the ground. How can I tell if the syncros and good and nothing is bent/worn out?
Thanks, guys
Old Mar 23, 2006 | 01:10 PM
Sparkles's Avatar
Nobody knows? Can anyone please help?
Old Mar 23, 2006 | 01:30 PM
postman's Avatar
when you crack it look at all the gears for chips or score marks on them also inspect the brass colred rings{dogteeth} make sure there still in good condition also check the side rings that go into dogteeth should be diamond shaped
TurboEM1
23
Apr 28, 2006 04:09 AM
jaycetan
Mar 30, 2005 11:33 PM
boostedcivichatchbacksi
May 12, 2004 05:00 PM
arw321
Mar 11, 2003 10:28 AM
