stock exhaust with b series swap
Old Mar 23, 2006 | 07:50 AM
EH-3's Avatar
Default stock exhaust with b series swap
anyone running stock exhaust system with a b series on an eg? if so, what header/cat/midpipe/axle back combination works?
Old Mar 23, 2006 | 08:25 AM
db8gsr_teg's Avatar
im running a gsr motor in a eg with modded cat with stock si hatch piping
Old Mar 23, 2006 | 08:49 AM
EH-3's Avatar
Default Re: (db8gsr_teg)
what do you mean by modded cat? what'd you do to it?
Old Mar 23, 2006 | 09:48 AM
db8gsr_teg's Avatar
ohh when i bought the car is was like this except it had a catback exhaust on. The cat that is on my car is smaller than other honda cat so it needed to be extended so thats why the cat is modded. If you dont understand me then i'll post some pics later
Old Mar 23, 2006 | 09:55 AM
db8gsr_teg's Avatar
Default Re: stock exhaust with b series swap (EH-3)
here some pics of the modded cat
http://i37.photobucket.com/alb...4.jpg
http://i37.photobucket.com/alb...3.jpg
http://i37.photobucket.com/alb...2.jpg
Old Mar 23, 2006 | 10:36 AM
Gadget's Avatar
Default Re: stock exhaust with b series swap (db8gsr_teg)
don't quote me on this..
I believe the stock B-Series exhaust manifold, B-Series Cat (Integ), and stock piping will work after you lengthen the stock pipe.. the cat bolts up, but is too far from the collector by about 2-3 inches.. you can't use a D-Series cat because the bolt indexing on the manifold flange is off by 90 degrees..
Old Mar 24, 2006 | 11:13 AM
EH-3's Avatar
Default Re: stock exhaust with b series swap (Gadget)
thanks.
95EGciv
Jul 31, 2008 08:37 PM
WalkerGSR1
Jan 6, 2007 10:32 PM
brainiak
Feb 6, 2004 06:05 PM
comptechgsr
Mar 23, 2003 11:25 AM
