ZC Swap Wiring Help! (Pics included...)
Old Mar 22, 2006 | 06:43 PM
Tippyman's Avatar
Default ZC Swap Wiring Help! (Pics included...)
First off, it's an SOHC ZC engine going into a 91 Std. Hatchback.
Here's my injector resistor box:
So, I'm going to list the steps I have and you tell me if they are correct! (Sounds simple enough, right?)
Step 1: Connect the two Yellow/black wires together, (the ones that were connected to the 2 DX injectors) then connect them to the Yellow/black wire on your injector box.
BEFORE:
AFTER:
Do I splice it like this? I have all four cut yellow/ black wires twisted together. Is that correct?
Step 2: -The yellow wire from the DX injector goes to Injector #1 (brown wire)
-The Red wire from the DX injector goes to Injector #3 (blue wire)
-Connect the wire you installed at A2 to Injector #2 (red wire)
-Connect the wire you installed at A4 to Injector #4 (yellow wire)
BEFORE:
AFTER:
I connect them here?
Step 3: Connect the 4 red/black wires from injector resistor box to each injector.
BEFORE:
AFTER:
Now then, that all seems OK if I have it right, but what do I do with these wires?
Do I just leave them? Take them outta the plug? Or do they belong somewhere?
And what do I do with this wire? Leave it alone?
Thanks alot!
-Tippyman
Old Mar 22, 2006 | 07:49 PM
boostedblkef's Avatar
Default Re: ZC Swap Wiring Help! (Tippyman)
not sure with this resistor box its alot esier if you got a 91 si resistor box to use i can tell you with that one
Old Mar 22, 2006 | 08:05 PM
Tippyman's Avatar
I realized I had excess wiring i didn't need.
In essence, the box should be made to look like this, right?
Old Mar 23, 2006 | 01:38 PM
Default Re: ZC Swap Wiring Help! (pitbullracer)
yes
dem0nk1d
Aug 16, 2007 02:58 PM
Tippyman
14
Mar 27, 2006 08:55 PM
Tippyman
Mar 23, 2006 06:40 AM
zccrx
Apr 2, 2003 07:03 AM
tdc
Feb 9, 2002 03:23 PM
