To turbocharge or not to turbocharge? (D16Y7)
Old Mar 22, 2006 | 06:11 PM
big-cat's Avatar
Default to turbocharge or not to turbocharge? that is the question
ok so i have a d16y7 motor (i know its just plain all out slow). now im thinking of piecing together a turbo kit of my own. or should i just do an engine package swap ive done little research on how to piece together a turbo. i still need to learn a little more. but i only have say 1500dollars to spend. what is everybodys oppinion. if i were to do an engine swap it would be some sort of b16a or a b18c1.if i piece together a turbo i will do a complete kit hand picked, possibly some used parts. what would u guys choose im just looking for around 200hp. thx for any oppinions
Old Mar 22, 2006 | 06:24 PM
tallyturbo's Avatar
Default Re: to turbocharge or not to turbocharge? that is the question (big-cat)
to search or not to search. that is the question.
j/k i would turbo it if your only looking for 200hp.
Old Mar 22, 2006 | 06:48 PM
Han Solo's Avatar
if u can find a gsr swap for 1500, do that. but i dont think u can
Old Mar 22, 2006 | 06:55 PM
00CivicGirl's Avatar
Default Re: to turbocharge or not to turbocharge? that is the question (KINGSOL18)
pick up this months issue of Honda Tuning..it has an article on turboing the Y7
edit its the d17 they were talking about in this months issue** sorry
Modified by 00CivicGirl at 7:28 AM 3/23/2006
Old Mar 22, 2006 | 07:06 PM
strictly.business's Avatar
Banned
$1500 wont get you a swap, even a b16a, or a turbo kit with everything that you need. keep saving homie.
Old Mar 22, 2006 | 07:14 PM
EX-T's Avatar
Default Re: (strictly.business)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business &raquo;</TD></TR><TR><TD CLASS="quote">$1500 wont get you a swap, even a b16a, or a turbo kit with everything that you need. keep saving homie.</TD></TR></TABLE>
/\ Don't listen to that guy!
I have a buddy with 145whp and 160wtq on a Y7 with a T3 at 6psi and he only spent $1100 on everything, from oil line to Front Mount! You should definitely go turbo! If you do anything, I would stick with D16 slammer! If you blow it up you can have another for $200-$400!
I have a Y8 and I think I have about 180whp at 8psi on a 15g with other mods!
Definitely TURBO!!!!
Turbo NINJA!!!!!!!
Old Mar 22, 2006 | 07:19 PM
Banned
to properly run a turbo system you need to upgrade the injectors, fuel rail, fuel pressure regulator, usually the fuel pump, change spark plugs, get a turbo, a good manifold, piping intercooler, oil lines and do quite a bit of drilling and taping and welding.
Old Mar 22, 2006 | 07:20 PM
Banned
did i forget a dyno tune so you dont run lean at only 7 psi and stick your motor?
Old Mar 22, 2006 | 08:53 PM
QuickDxEk's Avatar
Tuboing the Y7 is a good way to go. You can start off simple and get the setup you want. Than has you want to go faster crank the boost and add some fuel and you will be all set. Dont let anyone try tell tell you the Y7is a shitty motor. I have a dx coupe with a Y7 with bolt ons and walks all over z6 and y8 motors-Its all in the tune!!
Old Mar 23, 2006 | 08:46 AM
big-cat's Avatar
that sounds awesome. so turbo probably. the only thing im afraid of is the motor blowing. like im not sure how strong those motors are? may i should get some forged parts?? thx guys
Old Mar 23, 2006 | 08:51 AM
Turbo_y8's Avatar
are you joking. I pieced mine together for under 1500, 220whp out my d. You cant swap that in for a b!
Old Mar 23, 2006 | 09:02 AM
Miss_Bitch's Avatar
Boost the d series! It can easily be done for $1500 or lower!
Been there, done that
Old Mar 23, 2006 | 09:41 AM
Firstoost's Avatar
Your logic on the fuel setup is flawed, I only switched to 440cc when i went 10psi and am using all stock fuel system, and i didn't do much drilling, taping, and NO welding. Oh and also i'm running 210whp with a good tune on hondata and no problems. Vtec doesn't really matter too much, i know alot of guys on http://www.turbod16.com that have y7's boosted...you should sign up on the forum if you decide to boost it. I and alot of others are there most of the day helping out with no flaming
Old Mar 23, 2006 | 10:00 AM
DYRcivic's Avatar
boost the y7
been boosting since last summer still running strong
i only spent 1200 for everything
gotta love the D
Old Mar 23, 2006 | 09:09 PM
Turbo_y8's Avatar
Default Re: (DYRcivic)
i &lt;3 my boost D
Old Mar 24, 2006 | 05:10 AM
big-cat's Avatar
right now im just looking on ebay for parts but im not really sure on where else to look that is reliable on the internet. cause i know the internet is kind of sketchy ordering stuff and then u pay them and it doesnt come.
Old Mar 24, 2006 | 05:14 AM
big-cat's Avatar
but when i look for a turbo i should deff get a t3/t4 turbo. is there any thing else i should look into like isnt there diff. sizes???? and when i look for my turbo manifold is there any thing special i should look for in that either???thx for the help guys
Old Mar 24, 2006 | 05:26 AM
chippy's Avatar
Default Re: (big-cat)
budget? find a use HF or STD Manifold, and put a adapter plate on there. (BMCrace, spoolin performance, etc should have it) Then goto the junkyard and get a t3 from a volvo or a saab. t3 .42/.48 is perfect for the D's. Turbo and Manifold for under $250. that's a deal.
HF manifold - $40
Adapter Plate - $30
junkyard T3 - $100-$150
Old Mar 24, 2006 | 05:31 AM
Slow EJ8's Avatar
Default Re: (chippy)
In this situation with your power goals and budget I would say turbo the D. Make sure to do your research on parts and take your time to shop for them so you can ****** the good deals when they come up.
Old Mar 24, 2006 | 05:48 AM
big-cat's Avatar
hey does anybody know if god speed co. or xs racing co. have good intakemanifolds????
Old Mar 24, 2006 | 05:58 AM
Blind-Fashion's Avatar
Default Re: (Ap1 S2i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ap1 S2i &raquo;</TD></TR><TR><TD CLASS="quote">Boost the d series! It can easily be done for $1500 or lower!
Been there, done that </TD></TR></TABLE>
Must make you better then everyone else.. I hate posts like these
*edited* I like to be nice sometimes
Modified by Blind Fashion at 7:12 AM 3/24/2006
Old Mar 24, 2006 | 08:42 AM
penguinman717's Avatar
i gotta d series motor and its hella slow.....::shrugs:: get a ls motor if u can. if ur insterested my homie is selling one for 800 mounts and all dat.
Old Mar 24, 2006 | 08:51 AM
Turbo_y8's Avatar
Default Re: (penguinman717)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by penguinman717 &raquo;</TD></TR><TR><TD CLASS="quote">i gotta d series motor and its hella slow.....::shrugs:: get a ls motor if u can. if ur insterested my homie is selling one for 800 mounts and all dat. </TD></TR></TABLE>
can you read
Old Mar 24, 2006 | 09:03 AM
Everyones Hero's Avatar
Default Re: (tuck'd98)
Look at CCFabs manifolds. They're cheap and they're good. I was thinking about getting either his "Chuck Norris" or EL Ramhorn, but I'm going to be making my own.
Hell, if you're on a super budget look at what this guy did: https://honda-tech.com/zerothread?id=1564066
I'm running a small TD04 14G turbo @ 15psi. Semi-street tuend on Crome and I'm running 13.7 @ a little over 100mph in the 1/4. That's with a bad axle, blown turbo, and $35 crappy street tires.
If you look in the FI classifieds you can probably find a used Greddy kit for around $800.
NerdSports is putting down 273whp (I think) on a stock internaled D series.
Old Mar 27, 2006 | 04:27 PM
Firstoost's Avatar
Default Re: (Everyones Hero)
Yup i'm buying a ramhorn from josh(ccfab) aka hotrex. Once the GT2871r arrives i'll be @ 320whp instead of 210....wow what a difference that's gonna be. the size of your turbo will dictate lag and top end. I'm running a t3/O4E and it lags a little in the low end, but man it pulls to 7800 like nothing and wants more.
*edit* just try for something ball bearing...it makes a world of difference in spool time.
