Main Seal on D16Y8?
I am doing a timing belt change on my 99 civic with the D16Y8. I ordered:
1.) Timing Belt
2.)Water Pump
3.) New Water pump seal
4.) new Camshaft oil seal
5.) Tensioner
6.) tensioner spring
I was reading about main seals for the crankshaft. on http://www.HondaAutomotiveParts.com i couldnt find it but also in my helms manual i couldnt find it. Where is it at?
Also are there any more parts that I should order from honda b4 i start the t-belt job?
1.) Timing Belt
2.)Water Pump
5.) Tensioner
Usually the water pump comes with its own gasket, so I hope you didn't order that as a seperate part. Camshaft oil seal isn't something I've replaced before but having a new valve cover gasket is needed, along with HondaBond. Might as well do a valve clearance job while you've got things apart.
As for the front main seal - Part 17.
alright i was thinking that but i wasnt sure. ill do that when i change my clutch but that wont be for a while, the clutch still feels really solid(as in in very good working condition from what i can tell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing »</TD></TR><TR><TD CLASS="quote">your main seal is behind your tranny. Other side of the motor, you don't do that when you do a timing belt. </TD></TR></TABLE> You have to "main seals". The one behind the tranny is your "rear main". Most cars if never replaced leak a little or alot from here. The front main is the one in the picture.
would ureccomend me changing this main seal on the side of the engine in the pic? isnt it right behind the timing belt pulley thats off of the crankshaft?
no1knows908
Jul 14, 2007 07:06 PM
TRE_
May 3, 2006 06:32 AM
idriveadelsol7
Dec 8, 2005 06:00 AM
