how to clean intake mani while on car
Old Mar 22, 2006 | 04:59 PM
92civichatch1's Avatar
Default how to clean intake mani while on car
I have a b18b and after removing the intake today i saw alot of black tarry stuff. I dont have enough time to go rippin it off and cleaning it that way. So my question is this how do u clean the whole intake mani when its on the car?
I searched and saw that most ppl who had the intake situation like me took it off and used brake clean, simple green, dishwasher...etc. noone really left it on.
thanks
Old Mar 22, 2006 | 05:51 PM
Default Re: how to clean intake mani while on car (92civichatch1)
bump help me out
Old Mar 22, 2006 | 09:07 PM
95b16ej1's Avatar
Search for seafoam it tells you how to use it . it will clean your engine inside
Old Mar 22, 2006 | 09:35 PM
SiYouLater's Avatar
Do you want to clean the inside or outside? If its the inside, use seafoam deep creep or carb cleaner.
Old Mar 23, 2006 | 07:25 AM
Default Re: how to clean intake mani while on car (99FBPSi)
I want to clean the inside of the intake mani. I dont wanna use seafoam. I just wanna spray something in there that will clean it out and not have any damage to the motor. its my daily driver and its all i got so it cant go down. Whats the difference in the deep creep as compared to the seafoam? Is it just the sprayable version?
Old Mar 23, 2006 | 07:28 AM
db8gsr_teg's Avatar
just use seafoam, its a good product. If you wanna know how to use seafoam go search for their website
Old Mar 23, 2006 | 07:41 AM
Default Re: (db8gsr_teg)
i kno how to use seafoam. i have a higher mileage motor and i dont want the carbon that may be holding things together to be taken away.
Old Mar 23, 2006 | 07:45 AM
alispoon's Avatar
okay this is wat i got, i bought throttle body cleaner in a spray can from a locall parts store(canadian tire) lol. and while the car is runing, u open ur intake and u spray that in there, to avoid the car to turn off, push the gas liver a little. that thing cleans the inside of the throttle body and intake mani real good.
Old Mar 23, 2006 | 08:32 AM
fwdtamiya's Avatar
Default Re: (92civichatch1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civichatch1 &raquo;</TD></TR><TR><TD CLASS="quote">i kno how to use seafoam. i have a higher mileage motor and i dont want the carbon that may be holding things together to be taken away. </TD></TR></TABLE>
Then you have to take off your intake manifold. You want it to go in your intake manifold, but not the rest of your engine?
Edit: Ok i gave it some more thought, if you had a duster and sprayed some seafoam on that, you could swab that around in there just like your ears
Modified by fwdtamiya at 2:05 PM 3/23/2006
Old Mar 23, 2006 | 02:41 PM
Default Re: (fwdtamiya)
ok thanks for the replys i think im goin to try the carb cleaner method. but keep them comin
Old Mar 23, 2006 | 03:05 PM
old man neri's Avatar
Default Re: (alispoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alispoon &raquo;</TD></TR><TR><TD CLASS="quote">okay this is wat i got, i bought throttle body cleaner in a spray can from a locall parts store(canadian tire) lol. and while the car is runing, u open ur intake and u spray that in there, to avoid the car to turn off, push the gas liver a little. that thing cleans the inside of the throttle body and intake mani real good.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civichatch1 &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks for the replys i think im goin to try the carb cleaner method. but keep them comin</TD></TR></TABLE>
Get throttle body cleaner not carb cleaner. There is a difference, I forget what it is, but there is a diference. I think it has something to do with some sensors or something.
Old Mar 23, 2006 | 03:33 PM
SiYouLater's Avatar
Default Re: (old man neri)
Use seafoam deep creep. Its for claning throttle bodies and what not.
Old Mar 24, 2006 | 09:43 AM
Default Re: (99FBPSi)
well watll it be the deep creep or the throttle cleaner?
mrspeedy69
Jul 19, 2008 08:38 AM
tr0n9h
Jul 11, 2006 11:43 AM
DXhatchBack93
Nov 4, 2005 10:36 AM
djsire
47
Sep 15, 2004 07:48 AM
ijjz
Mar 18, 2004 11:51 AM
