Rewrite an EPROM possible?
Old Mar 22, 2006 | 04:17 PM
RTW DC2R's Avatar
Default Rewrite an EPROM possible?
looking to get a chipped ECU for my next setup (turbo), probably run Neptune, but not sure if I can just get a Hondata chipped ECU and write over it with Neptune or not? what are the limitations as far as rewriting an EPROM? can you burn over most chips with a different program or do you just need a brand new chip?
also, correct me if Im wrong, P28 has no knock sensor, and P72 has knock sensor?
Old Mar 22, 2006 | 05:25 PM
splitime's Avatar
Default Re: Rewrite an EPROM possible? (RTW DC2R)
All depends on the chip that was used. Get the part number off of it.
ie: 27c256 or 29c256 or 27sf512 etc...
Old Mar 23, 2006 | 03:47 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">looking to get a chipped ECU for my next setup (turbo), probably run Neptune, but not sure if I can just get a Hondata chipped ECU and write over it with Neptune or not? what are the limitations as far as rewriting an EPROM? can you burn over most chips with a different program or do you just need a brand new chip?
also, correct me if Im wrong, P28 has no knock sensor, and P72 has knock sensor?</TD></TR></TABLE>
Yes, you can reburn most roms thousands of times.
If you ever want to save or re-use that map in the future (or keep it and share it with others), then simply make a copy of it prior to erasing the rom and writing with neptune, crome, uberdate, etc...
p28 has no knock board, whereas p72 does.
take a look over at pgmfi.org in the noob sectionor faq/ wiki
Old Mar 23, 2006 | 04:12 AM
RTW DC2R's Avatar
yeah Ive checked out pgmfi, learned a lot but some of that eprom info is like another language. i figured it would depend on what kind of chip is used as to whether you can reburn another program onto it, etc. thanks for the info
Old Mar 23, 2006 | 07:42 AM
Fobtions's Avatar
Default Re: (RTW DC2R)
27c256 = eprom - uv eraseable
29c256 = EEprom - electronically eraseable
you want the 29c256.
Old Mar 23, 2006 | 07:46 AM
Asahi's Avatar
Default Re: (Fobtions)
I'd be surprised if a Hondata chip wasn't a 29c256. Shouldn't be an issue. Cheap to pick up a chip if you don't have the kind you need. Figure $5-$7 a chip, I keep 3 to 4 on hand for tuning Hondatas
Old Mar 23, 2006 | 07:55 AM
Fobtions's Avatar
Default Re: (Asahi)
hondata prefers to use the 29c256 for tuning purposes, cause u will be rewriting multiple times.
onced everything is tuned u will not need it to be rewriteable so a 27c256would be ok or a OTP "one time programmable.
Old Mar 23, 2006 | 08:03 AM
RTW DC2R's Avatar
but if a rewriteable chip already has Hondata on it, can you write over that with another program like Neptune? or can you only rewrite to it with the Hondata program?
thanks for the info!
Old Mar 23, 2006 | 08:06 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">but if a rewriteable chip already has Hondata on it, can you write over that with another program like Neptune? or can you only rewrite to it with the Hondata program?
thanks for the info!</TD></TR></TABLE>
It just stores data. You can rewrite it from any program... think of it like a cd-R or floppy disc. It doesn't care what's on it - data is data.
Old Mar 23, 2006 | 08:07 AM
Fobtions's Avatar
an eprom is an eprom, bits are bits .
yes you can rewrite whatever u want ; be it hondata, crome , neptune
Old Mar 23, 2006 | 08:09 AM
RTW DC2R's Avatar
thanks
Old Mar 23, 2006 | 09:34 AM
Aquafina's Avatar
I can get Rocket to burn a chip for you. P28. Either Hondata or Crome. PM'd you.
Old Mar 23, 2006 | 05:03 PM
743power's Avatar
Default Re: (Aquafina)
29c's are starting to get hard to come by
RTW DC2R
Apr 4, 2006 09:42 PM
DC2SIR-G
Mar 17, 2006 11:20 AM
SETI20
Aug 17, 2004 11:57 AM
VDoP-B18C1
Jul 12, 2004 03:55 PM
