fuel line goes to...nowhere? is there something missing?
Old Mar 22, 2006 | 04:04 PM
BB6racer's Avatar
Default fuel line goes to...nowhere? is there something missing?
i've noticed a tube under my car that starts at the top of the fuel filter i think (the big black can that is on the firewall below the fuse box) and goes down the firewall, starts to go under the car, and then just stops like it was cut or something. its a pretty big tube, probably 1/2" inner diameter and a 1/8" thick wall. is this some kind of evaporated fuel line or something? and if so, is it supposed to just stop like that under the car? i have a 98 base prelude FYI, thanks for any help. also, its just bothering me that this line empties out into the open atmosphere, and would it be possible for unfiltered air to go up the tube, into the black can, and into the motor?
Old Mar 22, 2006 | 04:07 PM
nonvteclude's Avatar
Default Re: fuel line goes to...nowhere? is there something missing? (BB6racer)
if it is a clear tube it is prolly the water drain, you'll also see those in the back and also from your sunroof.
Old Mar 22, 2006 | 05:26 PM
BB6racer's Avatar
found out the "black can" is oficially listed as "canister 2". any idea what it does?
Old Mar 22, 2006 | 09:08 PM
mgags7's Avatar
thats the vent for the evap system, leave it alone, it just vents vapors to the atmosphere
eg6 socal
Apr 3, 2014 04:05 PM
laziebun
Jun 24, 2009 05:17 PM
Justin Olson
Nov 3, 2005 03:17 AM
DieMaster
Aug 5, 2004 08:23 AM
