oil pressure sensor removal
Old Mar 22, 2006 | 02:24 PM
timmy0tool's Avatar
Default oil pressure sensor removal
motor in this case is an f22a1.
i'm trying to remove my oil pressure sensor but cannot even remove the darn wiring plug. is it screwed in? maybe from age it's been fused. is there a technique to get the wiring plug off?
also after removal of the plug what size is the sensor? my searching found that a 24mm deep socket works but there was also a reference to a 15/16" socket?! please clarify.
thanks in advance!
Old Mar 22, 2006 | 03:04 PM
SteveoBA8's Avatar
Default Re: oil pressure sensor removal (timmy0tool)
Remove the rubber cup piece(hot,cold,hot,cold,hot,cold probably made it stick on there) should be a phillips head bolt holding the wire terminal on. Use a socket for more torque instead of rounding the phillips head.
Old Mar 22, 2006 | 07:47 PM
aztecwhitelude's Avatar
The wires are held on by a nut. Best to use a socket on it. If I remember right it is an 8mm.
Old Mar 22, 2006 | 10:50 PM
twistedbydezign's Avatar
Default Re: oil pressure sensor removal (aztecwhitelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aztecwhitelude &raquo;</TD></TR><TR><TD CLASS="quote">The wires are held on by a nut. Best to use a socket on it. If I remember right it is an 8mm.</TD></TR></TABLE>
i think its 6mm, the thing is ******* tiny...but could be 8mm, be prepared with both sockets though..
Old Mar 23, 2006 | 08:35 AM
timmy0tool's Avatar
thanks guys yeah i had to pry the rubber piece off. it ended up cracking due to becoming brittle overtime. it's an 8mm screw to remove the wire. 15/16" socket worked for me to remove the sensor.
B_Swapped93
Oct 18, 2014 02:31 PM
timmy0tool
Mar 23, 2006 08:11 AM
97CWITR
Nov 10, 2005 07:31 PM
RACEPAK
17
May 19, 2005 04:53 AM
BlackB18CTeg
May 14, 2003 05:57 PM
