questions for the G23 swap
Old Mar 22, 2006 | 12:28 PM
Bottledh22's Avatar
Default questions for the G23 swap
so i spun a rod bearing in my h22 due to nitrous. i am now going to probably do the G23 swap in my car. my questions are how are they all motor, and by that i mean are the decently quick? how well do they do with boost on completely stock internals? do they bolt right up to the preludes? are these hard swaps and do the h22 heads bolt right on to the f23 block? sorry for all the qeustions guys but im just really curious.
Old Mar 22, 2006 | 01:04 PM
datac99's Avatar
Default Re: questions for the G23 swap (Bottledh22)
So... Uhhhhh... You mean h23? Try searching around with h23... It'll work out much better for ya' then swapping a moped motor into a prelude.
Old Mar 22, 2006 | 01:11 PM
Bottledh22's Avatar
no i mean the g23 swap. obviously you do not know what it is.
Old Mar 22, 2006 | 01:49 PM
The_Head's Avatar
Theres a few threads on this, read them.
Old Mar 22, 2006 | 02:06 PM
Bottledh22's Avatar
i have been...
Old Mar 22, 2006 | 02:11 PM
92SleeperH23's Avatar
Default Re: (Bottledh22)
Where's Pirate McFred when you need him? The G23 was a phrase he coined, If I remember
Old Mar 22, 2006 | 02:32 PM
The_Head's Avatar
Default Re: (92SleeperH23)
Yep do a search for his threads, also check this thread for the minor differences in mount requirements for the F23 block, it's a little different than the F22 block..
https://honda-tech.com/zerothread?id=1069869
Old Mar 22, 2006 | 05:32 PM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bottledh22 &raquo;</TD></TR><TR><TD CLASS="quote">so i spun a rod bearing in my h22 due to nitrous. i am now going to probably do the G23 swap in my car. my questions are how are they all motor, and by that i mean are the decently quick? how well do they do with boost on completely stock internals? do they bolt right up to the preludes? are these hard swaps and do the h22 heads bolt right on to the f23 block? sorry for all the qeustions guys but im just really curious.</TD></TR></TABLE>
thats a butt load of quetions, results are very good almotor, piratemcfred for 200whp and 183 wtq all motor..
boosting on stock internals is just like any other honda motor, they have their limitations, just changing the head on a h or f series doesn't make the bottom end any stronger
yes they bolt right up to preludes
depending on what chasis your swaping into makes it hard or not, for me all i did was swap a different block into a prelude and it was easy, everything prelude i already had because it went into a prelude!! if your going into an accord or other body its more work ..
and yes the h22 head just bolts up, as long as you block 2 oil ports.
Old Mar 22, 2006 | 08:12 PM
PirateMcFred's Avatar
Default Re: questions for the G23 swap (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">piratemcfred for 200whp and 183 wtq all motor..</TD></TR></TABLE>
Ahem, all motor nonVTEC that is.
lol
Pirate
Old Mar 23, 2006 | 05:34 PM
Default Re: questions for the G23 swap (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">
lol
Pirate
yes i forgot the vtak is wack for the pirate.. lol
Old Mar 29, 2006 | 01:06 PM
89a6T's Avatar
im building this motor also... so far i have
h22 head (no manifolds)
complete 98 f23vtec motor
i was asking pirate about custom pistons(should be able to getem the end of april)...first who to call.?second specs 4 11.5 cr. and i want to rev it to 8k if possible? if i get the pistons made to rev to75k would the bottom need to be balanced?
Old Mar 29, 2006 | 07:28 PM
ilikehonda's Avatar
damn it chase...the f23 is basicaly the same motor as the f22...preludes had f22's in them so bam problem with mounting solved...if it doesnt fit then guess what....CUSTOM mounts baby
Kuchtaboy
16
Aug 25, 2007 12:03 AM
boostin1cam
Nov 15, 2005 08:09 PM
jshelley45
Nov 7, 2004 12:46 PM
hondatuner123
Jul 23, 2004 05:34 PM
revlimitlude
Dec 17, 2002 11:57 PM
