wrong brake fluids
Old Apr 2, 2002 | 03:50 PM
S13 slide's Avatar
Default wrong brake fluids
what happens if you use a brake fluid thats not reccomneded? say if it needs dot 3 and you use dot 2 or 4? thanks
Old Apr 2, 2002 | 04:07 PM
SJP0tato's Avatar
Default Re: wrong brake fluids (S13 slide)
DOT 2 is a lower grade (meaning lower boiling points & possibly less corrosion resistance than any higher DOT number). Fortunately, your chances of actually finding any DOT 2 brake fluid are pretty slim...and if you do find it, leave it at it's better job of collecting dust. DOT 3 is more or less the standard, and DOT 4 exceeds DOT 3 (higher boiling points). Only downside to DOT 4 is the slightly higher price & it collects moisture slightly faster than DOT 3....as long as you flush your brake fluid at LEAST once a year you'll be fine. DOT 5 is silicone, good on restored classic cars & such...in other words, don't mess with it unless you KNOW you need it.
Good luck,
Ryan P.
kpjo4
Oct 19, 2010 09:48 AM
Powered by VTEC
Mar 12, 2008 08:09 PM
TheOne
Jul 20, 2003 03:28 PM
CivicSiRacer
24
May 15, 2003 12:03 PM
Flux
Nov 20, 2001 10:47 PM
