ys1 tranny+b18a=?clutch?
Old Mar 22, 2006 | 11:34 AM
efhonda91's Avatar
Default ys1 tranny+b18a=?clutch?
I'm in the process of buying a ys1 cable tranny for my b18a out of a 92 integra. My problem is while im swapping trannys i want to replace the clutch and flywheel. I dont know what clutch to buy, should it be for my motor or should it be for a b16 or doesnt it matter? Thanks.
Also is a 8 pound flywheel too light for a street car?
Modified by efhonda91 at 12:46 PM 3/22/2006
Old Mar 23, 2006 | 11:33 AM
tgreaves's Avatar
Default Re: ys1 tranny+b18a=?clutch? (efhonda91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efhonda91 &raquo;</TD></TR><TR><TD CLASS="quote">I'm in the process of buying a ys1 cable tranny for my b18a out of a 92 integra. My problem is while im swapping trannys i want to replace the clutch and flywheel. I dont know what clutch to buy, should it be for my motor or should it be for a b16 or doesnt it matter? Thanks.
Also is a 8 pound flywheel too light for a street car?</TD></TR></TABLE>
You get the clutch for the tranny.. Is your ys1 a bigshaft or small shaft? If its out of an usdm ls integra then its a small shaft.. It uses the same clutch as a 90-93 integra does.. The big shaft ys1 uses the same clutch as the hydro trannies except the throwout bearing is different..
Old Mar 23, 2006 | 11:59 AM
efhonda91's Avatar
Default Re: ys1 tranny+b18a=?clutch? (tgreaves)
Thanks, i actually havn't bought it yet. I'm pretty sure its a b16a tranny.
Old Mar 23, 2006 | 12:10 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efhonda91 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, i actually havn't bought it yet. I'm pretty sure its a b16a tranny.</TD></TR></TABLE>
All the ys1 are integra trannies.. Its either a usdm ls/gsr or jdm integra xsi..
Old Mar 23, 2006 | 03:27 PM
efhonda91's Avatar
what is the code for the sir tranny?
Old Mar 23, 2006 | 04:40 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">You get the clutch for the tranny.. Is your ys1 a bigshaft or small shaft? If its out of an usdm ls integra then its a small shaft.. It uses the same clutch as a 90-93 integra does.. The big shaft ys1 uses the same clutch as the hydro trannies except the throwout bearing is different..</TD></TR></TABLE>
you got that partially right.
the 90-91 a1/s1/j1/y1 use the 90-91 small spline clutch.
the 92-93 ys1 uses the 92-00 b-series clutch(large spline)
impreziv
Jul 20, 2008 10:53 AM
daidilus
Jan 6, 2006 04:59 AM
chadwick16
Feb 24, 2005 01:09 PM
URNVS
Jun 6, 2004 10:17 PM
DOHCarp
Mar 14, 2003 09:04 AM
