which tires size you guys vote for ?? for 15inches wheels
Old Mar 22, 2006 | 11:28 AM
aandrewcc's Avatar
Default which tires size you guys HAVE ?? for 15inches wheels
well, i have a 94 gsr. black/black.
have G/C coils. im going to lower my car around half a finger space gap between tires and fenders. which tire size you guys <U>have</U> ??
Modified by drewsointoyou at 9:08 PM 3/23/2006
Modified by drewsointoyou at 9:09 PM 3/23/2006
Old Mar 22, 2006 | 12:08 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: which tires size you guys vote for ?? for 15inches wheels (drewsointoyou)
Definitely 195/55-15, which is your stock size. It preserves the accuracy of your speedometer and odometer, preserves looks, won't rub, etc.
Old Mar 23, 2006 | 03:38 PM
aandrewcc's Avatar
bump for more vote !
Old Mar 23, 2006 | 05:49 PM
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewsointoyou &raquo;</TD></TR><TR><TD CLASS="quote">bump for more vote !</TD></TR></TABLE>
Democracy will not settle what is the best choice for you car. Just listen to the above post. ^^^
Old Mar 23, 2006 | 08:09 PM
aandrewcc's Avatar
Default Re: which tires size you guys HAVE ?? for 15inches wheels (drewsointoyou)
ok how about this ..
i changed it to.. which one u gyus have! ?
Old Mar 23, 2006 | 08:48 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewsointoyou &raquo;</TD></TR><TR><TD CLASS="quote">which one u gyus have! ?</TD></TR></TABLE>
I have 195/55-15 on my '94 GS-R, and 195/55-15 on my '01 ITR.
Old Mar 24, 2006 | 08:01 PM
aandrewcc's Avatar
more voting on which one u guys have on!
Old Mar 27, 2006 | 07:02 PM
aandrewcc's Avatar
i know we have more 15inch owner than that.
Old Mar 28, 2006 | 11:42 AM
Tornadom's Avatar
The way I see it, a wider contact patch will help your acceleration and braking, a longer contact patch will help your handling. Since the 205's are only making a slightly wider contact patch than the 195's I had to rule them out. The 195's provide a longer contact patch than the 205's. As far as total contact patch, the 195's provide more. The 195's get my vote.
Old Mar 28, 2006 | 01:48 PM
aandrewcc's Avatar
so..
205 = help your acceleration and braking
195 = better handling ??
is that correct ?
thanks for your help.
Old Mar 28, 2006 | 02:41 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewsointoyou &raquo;</TD></TR><TR><TD CLASS="quote">205 = help your acceleration and braking
is that correct ?</TD></TR></TABLE>
No.
You won't be able to notice any difference in acceleration, braking, or handling between 195/55 and 205/50 of the same tire.
If the tire you want is offered in 195/55, get 195/55. It will probably be cheaper. If it's not offered in 195/55, get 205/50.
Or, you can keep asking your question over and over and over and over and over again, and you still won't get a different answer...
Old Mar 28, 2006 | 02:46 PM
aandrewcc's Avatar
alright thanks
Old Mar 28, 2006 | 07:51 PM
Tornadom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewsointoyou &raquo;</TD></TR><TR><TD CLASS="quote">so..
is that correct ?
thanks for your help.</TD></TR></TABLE>
Theoretically yes.
In all actuality, no. The difference between the two sizes is so slight that no road going driver would notice different handling characteristics between them. As *nsxtasy* stated decide on the tire that you want to run, and if available in a 195/55 size get it, if only offered in a 205/50 that's okay too.
Old Mar 28, 2006 | 09:25 PM
aandrewcc's Avatar
thanks
Old Mar 29, 2006 | 06:45 PM
dreww..'s Avatar
I'm a 195/50 fan as of right now....when I boost the em1 I will most likely start usuing 205/50's...
Old Mar 30, 2006 | 09:32 AM
Kratos's Avatar
with a finger gap drop as you stated, i'd vote for the 205/50/15
turbo95eg6
Northwest (Sales)
18
Oct 23, 2008 12:09 PM
highroller54
May 6, 2008 08:23 AM
Hondatuner88
Feb 3, 2008 08:45 PM
DunkJDM
Dec 3, 2007 07:47 PM
hellasexyteg
Mar 27, 2007 01:41 PM
