rust-cleaning preferences
Old Apr 2, 2002 | 03:40 PM
rasta420's Avatar
Default rust-cleaning preferences
i have a 90 crx si and i have some rust building on both sides of the rear quarter panels, and on the rear hatch. what are some methods you guys use to get rid of rust and protect against it happening again?
Old Apr 2, 2002 | 03:49 PM
fiebru1119's Avatar
Default Re: rust-cleaning preferences (rasta420)
1) sand the paint off, sandblast it, bondo, repaint (for the hatch)
2) cut out square/rectangle piece of metal containing the rust, weld in identical size piece of sheetmetal and grind the welds until smooth, then repaint (this is for the quarter panels)
3) or you can get the acid stuff (im not too familiar with it) that will eat the rust off, and then use touch up pain until you can get it redone
hope this gave you an idea
Old Apr 3, 2002 | 09:40 AM
Cryptopsy's Avatar
Default Re: rust-cleaning preferences (fiebru1119)
For christs sake DON'T USE BONDO! That acid stuff neutralizes the rust, it works good. Rust resistant spray primer is good also. But rust is almost impossible to stop unless you remove it....kind of like cancer.
CPreston
Paint and Body
13
May 17, 2009 11:59 AM
ray_christopher
Paint and Body
Oct 28, 2008 06:36 PM
iheartDc2
Feb 5, 2006 01:47 PM
StreetEG
15
Jan 6, 2006 08:34 PM
