Sunroof having trouble going "up" but not back?!
Ok when I open my sunroof it has to lift up and back out of the hole. But when I try to open it up from a closed postion it has a hard time lifting out of the hole but once its past this position it'll go back and forth all day without a problem. Is there something that needs to be greased or tightened? Spring is coming and I wanna use it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19lude03 »</TD></TR><TR><TD CLASS="quote">sometimes you need grease...my body shop had to put some it cause mines closed and open really slow</TD></TR></TABLE>
I already greesed it and cleaned it and thats not the problem. Anyone else?
i know 92-95 civics have that problem just push up when trying to open itll be ok but if you want it fixed i belive its the motor is going bad. but im not 100% sure if thats it but it is on civic`s. if that helps.
dont mean to thread jack but mines kinda slow too how do you go about cleaning and greasing? yall talking about the tracks visible when open on top or greasing the motor?
mine has the same problem... it takes forever to open and close. hmm. how do you clean/grease that shiz? i thought maybe it was a bad motor, but now it seems like it just needs a cleaning and greasing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saosinx »</TD></TR><TR><TD CLASS="quote">mine has the same problem... it takes forever to open and close. hmm. how do you clean/grease that shiz? i thought maybe it was a bad motor, but now it seems like it just needs a cleaning and greasing.</TD></TR></TABLE>
lol maybe the majority of our ludes are doing it. this calls for a write up
someone do it
someone do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 »</TD></TR><TR><TD CLASS="quote">lol maybe the majority of our ludes are doing it. this calls for a write up
someone do it</TD></TR></TABLE>
agreed...
someone do it</TD></TR></TABLE>agreed...
mine is a little sluggish on the innitial push and final closing too. I just thought that was normal for a 13 year old moonroof motor
But if someone wants to let us know where/what they cleaned and greased to make their's work better, that would be awesome
sorry if i'm hijacking... but mine opens and closes fine, but it's loud when I close it. The passenger always gets freaked out when it shuts... lol. I've started warning people when I'm about to close it. Do you guys think cleaning/greasing would help this? What kind of grease is it and how do you apply it?
Here's how I do mine. When roof is fully open I mask off the opening so no aerosol sprays can damage the interior. I just use a paper stuck on the inside roof lining using masking tapes, then get some WD40 & spray all the sliders and runners that I can see, then rub it off with clean rags and do it until no more grime comes off the mechanism. When it's as clean as possible, I use some light spray on grease with one of those tubes so you can get right in and get it on all the clean sliders. Once this is done use some silicone spray on a cloth and wipe all around the sunroof rubbers, also on the inside metal frame that the rubber sits into. Once done remove the paper and tape and open and close a few times, you will find it smooth and also that clap sound isn't as loud because the rubber slides into position rather than gripping the metal and jumping into place. Hope this helps, it's what I've always done every year and have never had a problem, I figure the less stress & resistance the motor has to endure will make it operate smoother, faster and last longer.
schueytenten
Jul 10, 2007 03:36 AM
aws140
Jul 22, 2005 12:05 PM
Race Egr
Nov 5, 2004 03:41 PM
