maintainence
Old Mar 22, 2006 | 09:42 AM
skiptomylou's Avatar
Default maintainence
A close friend of mine has an Accord that is just a pointA to Point B car. Its a 94 Honda Accord LX with 130k+ miles on it. She bought it used and I'm pretty sure it was kind of neglected by previous owners. I've had the timing belt and water pump changed, put in new oil and filter and had the fluids topped off. My question is:
The next service I'm gonna do is flush the fluids. In addition to the transmission and radiator fluid flush, what else do I need to do?
Is there any other maintainence stuff I can do to keep the car running well?
Thanks.
Old Mar 22, 2006 | 10:35 AM
Honda-Master's Avatar
Default Re: maintainence (skiptomylou)
plugs NGK . wires Honda factory, fuel filter, pcv valve, injectors service, air filter, tranny fluid,brake fluid flush, valve adjustment, cap, rotor, if you just hat the timing belt and water pump done recently , the coolant should be new,,
Old Mar 22, 2006 | 04:16 PM
Ashland02's Avatar
Default Re: maintainence (Honda-Master)
IM not sure about a 94, But I know HOnda upped the emissions warranty to 150,000 miles. They will replace your cap and rotor, spark plugs, wires, oil and filter. Also, and cat problems or exhaust , and o2 sensors are covered. You might call and check to see if your car is covered! Hope I helped some!!
Old Mar 22, 2006 | 04:46 PM
YeuEmMaiMai's Avatar
Default Re: maintainence (Ashland02)
my cap, rotor and wires have 143K on them. I might replace the cap and rotor this year but they still look good and the car gets 32+ MPG
WaterHoes
Jun 24, 2013 09:45 AM
dman81
Mar 9, 2005 01:51 PM
jeremy.
Feb 8, 2005 10:42 AM
newhondaowner29
Aug 30, 2004 09:33 AM
4doorLX
Sep 13, 2002 08:36 AM
