GSR 2 stage Vtec, how does it work?
Old Mar 22, 2006 | 07:53 AM
GSRpoweredEJ's Avatar
Default GSR 2 stage Vtec, how does it work?
What is the trick behind the Integra GSR's 2 stage VTEC? I notice this from stock GSR engines. I can tell by the sound of the engine that the VTEC engages at @4500rpm, but I don't really feel any power until the engine revs up to 6500rpm. But at 6500rpm you feel that sudden boost of power. It's more different than when it is a rpm of 4500. Why is that? Anyone know the magic behind this? I know that it is because of the ECU. I don't get why the engine is feels so weak when it engages in the first stage of VTEC compared to the second boost. I've been looking around Google for a while and haven't found the answer so I came here for help.
Old Mar 22, 2006 | 08:34 AM
dwnthehatch's Avatar
Default Re: GSR 2 stage Vtec, how does it work? (GSRpoweredEJ)
It's the secondary runners on the intake manifold opening. not vtec.
Old Mar 22, 2006 | 09:01 AM
Default Re: GSR 2 stage Vtec, how does it work? (dwnthehatch)
I believe it has something to do with the engine and ecu, not the manifold, because I disabled the second runner flaps.
Old Mar 22, 2006 | 01:51 PM
FIGARILA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">It's the secondary runners on the intake manifold opening. not vtec.</TD></TR></TABLE> that sounds about right
Modified by Heron of Alexandria at 9:15 PM 3/28/2006
Old Mar 22, 2006 | 02:58 PM
JDMC-Kamel's Avatar
Default Re: GSR 2 stage Vtec, how does it work? (Heron of Alexandria)
ru serious????
Old Mar 28, 2006 | 08:14 PM
FIGARILA's Avatar
no i am not , i confused the d15b setup
sorry for the misinformation
Old Mar 15, 2020 | 03:59 PM
DOHC_Dilly's Avatar
I’m having the same questions. I have a full stock GSR swap in my ej8 and am running the stock manifold on a CHIPPED P28!!! With the vacuum lever on runner zip tied up, and all of the IAB vacuum lines disconnected. (Running FPR straight to manifold instead of the IAB vacuum splitter).
I AM EXPERIENCING THE SAME THING. I hear vtec crossover at 4400, and when I hit 6000 the actual crossover takes place with a real boost of power.
we need the actual schematics of how the inside of this manifold works if anyone has
Old Mar 16, 2020 | 07:49 AM
spAdam's Avatar
Loved
Community Favorite
It's all over the internet. There is no sorcery. You can enable the IABs on your P28 using an extra output (and possibly a relay, I forget if that is necessary or not) - obviously you'll have to burn a new chip.
Old Mar 24, 2020 | 07:05 PM
HiProfile's Avatar
Vtec engages at 4400, which isn't very audible, then 5750 the IAB's open. They are much more audible. If your ecu is chipped and has them flipped, you'll have a sizeable power loss between the engagement points. Vtec would be engaging late, IAB's opening early. A stock B16 computer opens vtec later than it needs to, also leading to a 'pop' in power and sound.
Google "ab0ve honda manuals" (first is a zero, not the letter o) and you find PDF's that have electrical schematics along with everything else you could possibly need.
type-GGSR
Apr 3, 2008 11:31 AM
DJP
Jul 23, 2007 08:24 PM
vipersr10
Jan 16, 2006 02:39 PM
b16a27
Oct 17, 2004 02:55 PM
jonoknut
Sep 11, 2002 08:18 PM
