Clutch wont REALEASE
I went to start the car today and hit the CLutch and it went straight to the floor. For the past couple of days the cars been making a rattling noise in first and second but I just figured it was the heat shield went....
First, check the hydralic clutch reservoir. You may have a slow leak and ran out of fluid. Refill it, bleed the system (via the bleeder screw on the slave cylinder) just as you would the brakes; and see if your pedal returns.
If still no good, check if anything came adrift (not likely, but you never know)
If eveything appears ok, I would now suspect the clutch pressure plate
P
P
it would be a hell of a lot easier for all of us who are trying to help you if you could let us know year and model ,,,you see . up to 1989 accords had a clutch cable if it broke , pedal goes to floor,, starting in 90 ,, it is hydraulic ,, if it is 90 or newer most likely you got a leak,, most likely clutch master cylinder or slave cylinder
put the year and model in your signature
if indeed it is an isuue with the clutch master or slave, go to this site, it has step by step instructions on how to replace and bleed system,,
http://www.ozaccord.com/forums/showthread.php?t=30
had this problem mabye a lil diff or the same i have a 90 accord lx and the clutch pedel went to the floor and stayd there and there was fluid in the reservoir but not much opend the bleed screw on my slave cyl. and only a lil fluid came out but mostly air and it turnd out that the rubber boot on the right side had a crack in it and was letting air in so i just changed it and never had a problem sence and it was like 25 bucks at auto zone for a new one easy to do to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda4674 »</TD></TR><TR><TD CLASS="quote">had this problem mabye a lil diff or the same i have a 90 accord lx and the clutch pedel went to the floor and stayd there and there was fluid in the reservoir but not much opend the bleed screw on my slave cyl. and only a lil fluid came out but mostly air and it turnd out that the rubber boot on the right side had a crack in it and was letting air in so i just changed it and never had a problem sence and it was like 25 bucks at auto zone for a new one easy to do to</TD></TR></TABLE>
had the same problem. removing the slave cylinder is a BITCH if you dont have box end wrenches
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">
had the same problem. removing the slave cylinder is a BITCH if you dont have box end wrenches</TD></TR></TABLE>
uhhhh...... most people use 12mm sockets.
ok i figured out its the slave cylinder but I cant figure out how to get the bolt that connects to the line off???? I tried wrenchs and it didnt work and I dont want to strip it....Is there a way to get the line to come out before taking the bolt out????thanks
You need what is called a Flare Nut Wrench. It's much like an open end wrench, but is much deeper and engages Five (5) of the Six (6) sides of the nut; thus avoiding rounding it off.
P
P
Scotty Dosent Know
May 31, 2009 04:53 AM
