just done with swap....NO CLUTCH.NEED HELP ASAP
I have a 95 ex coupe with a 98 type r motor and 00 type r lsd. (I bought the tranny sepertly then put it together) we just did the swap yesterday everything went fine... We bleed the clutch and started right up. But this morning I go out to my car I start it up and I have no clucth the pedale just satys at the floor. I tried bleeding it but still same thing. What could be wrong
Yeha I checked the the resevor and thr master cylinder.when I checked the master cylindere from inside of the car there was some fluid but not greatly a lot. When I bleed the clutch we always pump the paddle by hand. If it is the resevor how could this had happened
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nello a. »</TD></TR><TR><TD CLASS="quote">master or slave probably.</TD></TR></TABLE>
I had the same problem when my slave went out. You could have pinched a line when you put the swap in also.
NFrank89
Transmission & Drivetrain
Nov 30, 2009 07:27 PM
david236kEG
23
Jan 28, 2009 03:34 PM
ninety9ex
May 3, 2004 02:01 PM
