ITR/koni install
I'm having a little problem installing ITR shock components to my new Konis.
First of all, ITR Damper Mounting Rubber does not slide into the Koni shock. The Damper Mounting Collor that was provided by Koni slides in fine but when I try to install the damper mounting rubber, the diameter of the hole in the rubber is too small. is it okay to enlarge the hole in the rubber?
Same problem with the Bumper Stop. The diameter in the bumper stop is too small. Is it okay to enlarge?
thanks.
thanks.
