QTP e cutout?...
Old Mar 21, 2006 | 08:23 PM
turbochargeb18c's Avatar
BANNED
Default QTP e cutout?...
have anyone have any experience or tried one the QTP e cutout before?...just need to know if they perform as good as the dmh e cutouts such as the opening and closing of it and if they open all the way...ive heard some e cutouts doesn't open all the way like they suppose to...
http://www.quicktimeperformanc...&p=25
Old Mar 22, 2006 | 05:44 AM
BANNED
Default Re: QTP e cutout?... (turbochargeb18c)
anyone?...
Old Mar 22, 2006 | 08:06 AM
Emshhh's Avatar
a friend has one on his 240. it worked till he hit something on the road then it broke... but that's not really the qtp's fault.
personally, i run a dmh and i love it, never had a probelm yet, and it fully opens and closes! quickly too.
when i was researching cutouts, i read that the qtp break more often... idk.
Old Mar 22, 2006 | 04:55 PM
Pootie's Avatar
i heard there's a break-in procedure for the qtp, so that it seals properly. Is this true? If so, what is the method? Thanks
Old Mar 23, 2006 | 12:21 PM
fox three's Avatar
Default Re: (Pootie)
DMH is generally regarded as the best electric cut out around here. I've never had a problem or seen a problem with them.
QTP's however have leaked on a friends fbody.
Old Mar 23, 2006 | 12:49 PM
elevatedj32's Avatar
I use one and give it more attention than anything else on the car. It leaks, so the fix is high temp RTV to help it seal. It sticks sometimes because of the RTV and as of late, I have to tap the motor while activating the switch to make it work, I believe it's toast, but having one is fun when it's working.
Old Mar 23, 2006 | 01:46 PM
BANNED
Default Re: QTP e cutout?... (elevatedj32)
cool thanks guys...i think im gonna get the dmh one then...can afford any f*cks...
Old Mar 23, 2006 | 02:35 PM
SPOON_BeIgHtEeNsEe's Avatar
i have one... but havent used it yet... hopefully it doesnt leak or breakdown...
Old Mar 23, 2006 | 03:09 PM
MidShipCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elevatedj32 &raquo;</TD></TR><TR><TD CLASS="quote">I use one and give it more attention than anything else on the car. It leaks, so the fix is high temp RTV to help it seal. It sticks sometimes because of the RTV and as of late, I have to tap the motor while activating the switch to make it work, I believe it's toast, but having one is fun when it's working.
What brand do you have?
Old Mar 23, 2006 | 03:52 PM
NastyHabitzCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pootie &raquo;</TD></TR><TR><TD CLASS="quote">i heard there's a break-in procedure for the qtp, so that it seals properly. Is this true? If so, what is the method? Thanks</TD></TR></TABLE>the DMH one says to run the car with it closed on first start-up. and then drive it a little to seal it then your set.
Old Mar 23, 2006 | 05:26 PM
Default Re: QTP e cutout?... (MidShipCivic)
Quote, originally posted by MidShipCivic »
Old Mar 23, 2006 | 05:52 PM
Turbocivic94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbochargeb18c &raquo;</TD></TR><TR><TD CLASS="quote">cool thanks guys...i think im gonna get the dmh one then...can afford any f*cks...</TD></TR></TABLE>
run the 4" exhaust fawker
Old Mar 23, 2006 | 06:08 PM
BANNED
Default Re: QTP e cutout?... (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">
run the 4" exhaust fawker </TD></TR></TABLE>
too rich for my blood...dont have the kind of money like you
Old Mar 23, 2006 | 06:17 PM
TurboEM1's Avatar
I have a 60mm exhaust. Do they make one that size? I only see 2.25, 2.5, 3, ect.. Do i have to custom make the pipe?
Old Mar 23, 2006 | 06:49 PM
too rich for my blood...dont have the kind of money like you </TD></TR></TABLE>
I buy my parts with Food Stamps
Old Mar 23, 2006 | 06:52 PM
BANNED
I buy my parts with Food Stamps </TD></TR></TABLE>
**** i used wic...
Old Mar 23, 2006 | 08:27 PM
fox three's Avatar
DHM just quit working on my girlfriends car tonight!
Probably a loose wire, I'll let you guys know if it actually failed.
Old Mar 23, 2006 | 10:45 PM
Default Re: QTP e cutout?... (fox three)
off topic but has anyone tried the VES (Virtual Exhaust System)
http://www.atpturbo.com/root/r...4.htm
Old Mar 24, 2006 | 02:49 AM
Default Re: QTP e cutout?... (SPOON_BeIgHtEeNsEe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_BeIgHtEeNsEe &raquo;</TD></TR><TR><TD CLASS="quote">off topic but has anyone tried the VES (Virtual Exhaust System)
Hmm exhaust just loves making 90 degree angles ....
Old Apr 20, 2006 | 08:41 PM
90 Si Hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox three &raquo;</TD></TR><TR><TD CLASS="quote">DMH is generally regarded as the best electric cut out around here. I've never had a problem or seen a problem with them.
QTP's however have leaked on a friends fbody.</TD></TR></TABLE>
where to buy the "DMH?"
Old Apr 20, 2006 | 09:44 PM
mrbsponge's Avatar
also this doesnt even open till a few psi of boost, which to me is not where i want it to open, i want it to be open when im trying to get into boost. not when i am alrady there
daigo
Oct 1, 2011 02:49 PM
turnsignalandy
16
Apr 10, 2008 05:58 AM
RR98ITR
Dec 3, 2005 05:33 PM
ALF
Jul 24, 2001 01:47 PM
