rear wheel bearings
So I finally got around to getting the rear wheel bearings changed, just bought the whole hub assembly. Anyway I took the old hub out and in the back the bearings were exposed and on the new one's there's a ring or plate of some sort(I think they're greaseless) my question is now the new hub wont slide all the way back onto the shaft and I think it's because part of the old hub is still on there, how do I get the old part of the hub off?. It's about 10:30pm so I've lost all my light otherwise I would have taken pics. Thanks for any help.
Thanks for the help, I was slightly unclear in my first post so let me clear up my problem. I took off the old hub assembly to replace it with the new hub assembly and the new assembly doesnt slide all the way back on the spindle. I cant even begin to thread the bolt. After checking the back of the new assembly and the old assembly I noticed that the old assembly has the wheel bearings exposed but the new assembly does not. I am afraid I might have left part of the old assembly in.
Thanks, I'll post pics tommorrow when I get up and actually have daylight. If I did leave it on, I did try and budge it back but it wasnt moving so I may end up trying to use vice grips and a hammer to get it off the spindle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pavix »</TD></TR><TR><TD CLASS="quote">Thanks, I'll post pics tommorrow when I get up and actually have daylight. If I did leave it on, I did try and budge it back but it wasnt moving so I may end up trying to use vice grips and a hammer to get it off the spindle</TD></TR></TABLE>
Don't do anything crazy!
haha this happened to me on my old prelude. the bearings were so shot the cover was stuck on the hub. You can either use a flat blade screwdriver and pry with it or i used a huge pair of channel locks and wrenched on it and got it off fairly easy. try some wd40 and grease to help you out. doesn't matter if u hurt the old bearing cover just try not to mess up that hub.
The Bearing Race is stuck on the Spindle. I just did the front bearing on my Vigor and same thing happened. Air chisel,Heat and WD40 will be your friend. Good Luck
MarkCayabyab
Oct 7, 2017 11:40 AM
CRX7
Mar 17, 2002 01:44 PM
