how to hook up msd inline fuel pump to distributor???
Old Mar 21, 2006 | 07:28 PM
efb20vtec's Avatar
Default how to hook up msd inline fuel pump to distributor???
i got an inline dont know how to run it straight to dizzy,had it run off a switch before..too dangerous.help??
Old Mar 22, 2006 | 06:31 AM
EE_Chris's Avatar
Default Re: how to hook up msd inline fuel pump to distributor??? (efb20vtec)
Hooking up an inline fuel pump to a distributor doesn't make much sense. What is it you're trying to accomplish?
If you're trying to make the fuel pump turn on when the engine starts, use a relay and the fuel pump control wire that the ECU currently uses to turn on/off the stock fuel pump.
Old Mar 23, 2006 | 12:23 AM
efb20vtec's Avatar
Default Re: how to hook up msd inline fuel pump to distributor??? (EE_Chris)
yeah i want it to be on whenever i drive my car,so i dont forget to turn it on.i just thought that hookin it up to the dizzy would be easiest.how would i use a relay?
Old Mar 23, 2006 | 07:15 AM
EE_Chris's Avatar
Then yeah, just use the ECU's fuel pump control wire to turn a relay on, which in turn applies voltage to your fuel pump. If you're asking how to actually hook up a relay, How Stuff Works has a great little write-up.
Old Mar 23, 2006 | 11:26 AM
tgreaves's Avatar
Tap off of the wire for the main relay and run it to another relay and then to the inline pump.. I think its wire #7 on the main relay harness..
I wouldnt use the dizzy but if you really want to, its the thick wire that is on the 2 plug harness.. DONT POWER THE PUMP FROM THAT WIRE, just use it to switch a relay..
girlcrx
Mar 9, 2014 06:04 PM
pleej
Apr 8, 2011 11:06 AM
thegooddoctorceretti
Audio / Security / Video
Sep 18, 2007 06:27 PM
Jamison
Jul 11, 2002 12:07 PM
RCSIVTEC
May 12, 2002 10:14 PM
