will 96-00 shocks fit a 92-95?
Old Mar 21, 2006 | 05:36 PM
Sleepy_Red_hatch's Avatar
Default will 96-00 shocks fit a 92-95?
as title states. will it? if so, what mods? (KYB AGX's btw)
Old Mar 21, 2006 | 05:38 PM
one bad dx's Avatar
Default Re: will 96-00 shocks fit a 92-95? (Sleepy_Red_hatch)
all suspension components from 92-00 on civic's are interchangeable, also 94-01 teg's.
Old Mar 21, 2006 | 05:40 PM
BlueIntegraBoy's Avatar
Not the rear struts
Old Mar 21, 2006 | 05:41 PM
Default Re: will 96-00 shocks fit a 92-95? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Not the rear struts</TD></TR></TABLE>
how come?
Old Mar 21, 2006 | 05:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
how come?</TD></TR></TABLE>
The 92-95 Civic rear strut, on the fork part, is wider than the 96-00 Civic strut. Which means the 92-95 Civic rear LCA, is thicker than the 96-00 Civic LCA. If you shave down the bushing, I think it will fit.
Old Mar 21, 2006 | 06:05 PM
The 92-95 Civic rear strut, on the fork part, is wider than the 96-00 Civic strut. Which means the 92-95 Civic rear LCA, is thicker than the 96-00 Civic LCA. If you shave down the bushing, I think it will fit.</TD></TR></TABLE>
you mean the EG ones are thinner and i would need to add spacers, rather then shaving anything?
Old Mar 21, 2006 | 06:08 PM
SOHC4life 96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">you mean the EG ones are thinner and i would need to add spacers, rather then shaving anything?</TD></TR></TABLE>
No, other way around. The LCA bushing on the 92-95 civics is thicker than that of the 96-00 civics. So you could add spacers to the shock on a 96-00 using 92-95 struts but not the other way around. I know this because I've done this.
Old Mar 21, 2006 | 06:16 PM
Default Re: will 96-00 shocks fit a 92-95? (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">
No, other way around. The LCA bushing on the 92-95 civics is thicker than that of the 96-00 civics. So you could add spacers to the shock on a 96-00 using 92-95 struts but not the other way around. I know this because I've done this.</TD></TR></TABLE>
cool thanks.
Old Mar 21, 2006 | 06:23 PM
EckoTech
Guest
Posts: n/a
thats correct, but 92-95 civics and 94-01 integras are completely interchangeable.
Old Mar 21, 2006 | 07:00 PM
Gadget's Avatar
Default Re: will 96-00 shocks fit a 92-95? (EckoTech)
you just had to get the last word in didn't you..?
Old Mar 21, 2006 | 07:02 PM
Default Re: will 96-00 shocks fit a 92-95? (Gadget)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gadget &raquo;</TD></TR><TR><TD CLASS="quote">you just had to get the last word in didn't you..? </TD></TR></TABLE>
no, i did
Old Feb 1, 2007 | 03:28 PM
Wazup's Avatar
back from the dead..
how do you SHAVE down the bushing?
Old Feb 2, 2007 | 11:51 AM
verycleanhatch's Avatar
Default Re: will 96-00 shocks fit a 92-95? (Wazup)
i used a rotary grinder with some metal disc. i took my forever to do mine.
Old May 27, 2007 | 06:43 PM
dafuzzbudd's Avatar
Default Re: will 96-00 shocks fit a 92-95? (verycleanhatch)
i have eg shocks that i want to put on my ek
from what i understand i need spacers...
what are we talking here, washers?
Old May 27, 2007 | 06:51 PM
user 98292739's Avatar
Default Re: will 96-00 shocks fit a 92-95? (dafuzzbudd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd &raquo;</TD></TR><TR><TD CLASS="quote">i have eg shocks that i want to put on my ek
what are we talking here, washers?</TD></TR></TABLE>
yup i just put my CRX d2 coilovers on my 97 hatch.
all you need to do is go to a hardware store. Take your LCA bolt with you(i had extras) and go to the washer section and find one that fits your bolt snugglin so it doesnt move around to much.
i ended up with 12 washers 3 washers on each side of the LCA so 6 on each side.
works great
Old May 27, 2007 | 07:22 PM
dafuzzbudd's Avatar
Default Re: will 96-00 shocks fit a 92-95? (The Lobster)
this is only the rear, correct?
incase they ever need to be replaced... will replacing my lca's with eg's work?
Old May 27, 2007 | 07:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd &raquo;</TD></TR><TR><TD CLASS="quote">this is only the rear, correct?
incase they ever need to be replaced... will replacing my lca's with eg's work?</TD></TR></TABLE>
no sir EK are 1 inch longer. or something like that
oh ya with the spacers the space is 10 mm...so 5 mm on each side...the washers i use equaled to 10 mm with 6 washers...so meassure them out since each washer is diff size.
RACEPAK
12
Apr 17, 2006 04:34 PM
1POINT8VTEC
Jan 24, 2006 12:06 PM
zephyrantes
Jul 12, 2005 07:20 PM
Shongku
Aug 5, 2004 09:14 PM
JDMDC5888
Apr 4, 2004 06:20 AM
