Head stripped where temp sending unit goes!!!
Old Mar 21, 2006 | 05:24 PM
91integracer's Avatar
Default Head stripped where temp sending unit goes!!!
I bought a new temp sender... took the old out threaded the new in.. put a wrench on it and noticed it was a little tight. took it out and saw that its now stripped where it threads in.. The old won't thread in anymore and now the car sits waiting for a tow. Amazing! How much should this cost me?
Old Mar 22, 2006 | 10:32 AM
aspec101's Avatar
Default Re: Head stripped where temp sending unit goes!!! (91integracer)
your will need to helicoil it. You can get this from your local autoparts store. You will need to make sure none of the shavings get into your coolant passages though. I have found some grease on the tap holds the shavings to it instead of letting them into the motor.
Lei Siew Long
Dec 2, 2011 12:00 PM
martn53
Aug 30, 2009 08:15 PM
DA is best
May 6, 2006 04:05 AM
civictypenos
Aug 6, 2004 07:02 AM
