Ate Super BLue fluid
Old Mar 21, 2006 | 02:11 PM
lude98SH's Avatar
Default Ate Super BLue fluid
Ok probably this weekend im going to be switching over to this fluid. My question is how much will I need to bleed the whole system ? Also does anyone have any experiences with this fluid, good/bad ?
Old Mar 21, 2006 | 02:15 PM
soundbomber's Avatar
Default Re: Ate Super BLue fluid (lude98SH)
1 tin should be enough. I've used it before and it is the shizznittlebimbamgangsta. highly recommend it
Old Mar 21, 2006 | 06:17 PM
darockstar's Avatar
what is this
Old Mar 21, 2006 | 06:23 PM
Default Re: Ate Super BLue fluid (darockstar)
brake fluid
Old Mar 21, 2006 | 06:38 PM
fast+forward's Avatar
Default Re: Ate Super BLue fluid (soundbomber)
one is more than enough, good stuff
Old Mar 21, 2006 | 06:52 PM
dman100's Avatar
I used that stuff in my DSM.... honestly, I couldn't tell one bit of difference
Old Mar 21, 2006 | 08:04 PM
iLude's Avatar
Default Re: Ate Super BLue fluid (dman100)
only difference is higher boiling point. They only time you'd probably notice a difference is on a track...
Old Mar 22, 2006 | 02:57 AM
Honda318dx's Avatar
Default Re: Ate Super BLue fluid (iLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iLude &raquo;</TD></TR><TR><TD CLASS="quote">only difference is higher boiling point. They only time you'd probably notice a difference is on a track...</TD></TR></TABLE>
Yeap, don't use this fluid on the street, unless you track your car. Race fluid has a tendency to draw in moisture faster, thus reducing the boiling point. Just get that castrol brake fluid, its more than fine for the street. Ford HD brake fluid is pretty awesome as well, a lot of racers I know use it.
Old Mar 22, 2006 | 04:22 AM
CurlyDE's Avatar
If you do use this in a street car, you may want to change it more frequently (because of the moisture issue pointed out by Honda318dx). I completely flush the fluid in my Prelude and 951 either every 6 months or 2 track weekends (whatever comes first).
blulude92
18
May 25, 2006 12:02 PM
Sehc Tib Alli Zerif!!!!!
Feb 15, 2006 01:05 PM
RaceMyGhost
Jan 12, 2006 11:09 AM
SurferX
Feb 6, 2003 11:54 AM
CivicSiRacer
53
Apr 9, 2002 08:31 PM
