help me decide with suspension!
Right know i have 5 zigen springs with stocks shocks. I want to get koni yellows. But i thought about switchin out the springs with ground control coilovers and getting kyb agx shocks with it. Do you all think i should switch my springs and get coilovers, or just keep springs and get some koni shocks.
I personally like the coilovers. Allows you to adjust the height evenly as the springs settle. No uneven drop here. I think it looks funny when the back of a car is lower then the front.
[Modified by Fooser, 10:08 PM 4/2/2002]
If you want GC's I would definitely get the Konis to go with it. Keep in mind that the Konis allow limited ride height adjustment. I used it on the rear to even it out (my car sat higher in back w/ all perches set on stock height
does ground control for koni cost more? cheapest i seen for ground control is 279 on massive motorsports but dont know if it is more expensive when getting ones for koni. Thanks.
neozero999
Suspension & Brakes
17
Sep 4, 2008 06:54 AM
