I need help!
Old Mar 21, 2006 | 10:22 AM
TylerB's Avatar
Default I need help!
Fuel Pump not working!!
Relay is 2 days old.
Relay getting power and working.
Fuel Pump is in working order (*Hotwired)
I checked for power in the wires to the pump. Only one is getting very LITTLE power.
d16y7 w/p28
Please help me!!
Is it the ECU? Grounds? Wiring?
Old Mar 21, 2006 | 10:27 AM
...Lloyd Braun...
Guest
Posts: n/a
Default Re: I need help! (EG#CSS)
<-- Y7 on P06 here, everything works great.
was your P28 converted to run your Y7?
only thing I can think of is a loose ground because you said it's getting LOW voltage. Usually if it was something malfunctioning it would be either full power, or no power, not constant low power.
this is all IMO good luck.
Old Mar 21, 2006 | 09:30 PM
TylerB's Avatar
Default Re: I need help! (...Lloyd Braun...)
The p28 wasnt converted as i was planing to put a z6 head on the y7 block.
grounds that i've checked and are tight:
<U>valve cover to front
passenger mount to body
tranny to body</U>
Am I missing a big ground somewhere?
About the low voltage, tested it with a test light and the light is very dim...
Any more sugestions?
Old Mar 22, 2006 | 01:01 AM
TylerB's Avatar
bump
JRciv
Engine Management and Tuning
45
Feb 16, 2023 01:27 PM
xavierS
Mar 25, 2018 04:41 PM
Louis53123
May 1, 2011 05:36 PM
hwnstyle21
Sep 9, 2002 03:57 PM
