Power Steering Sensor
Old Mar 21, 2006 | 08:59 AM
burningwrek's Avatar
Default Power Steering Sensor
I'm almost through swapping my b20 into my 98 ex coupe and the last sensor I have to plug in is the power steering speed sensor. I can't find the plug that snaps into the plug on the power steering line. I thought it was on the harness but apparently it isn't. Is that sensor necessary to run the motor WITH power steering? If it is, where will the sensor be at on the b20 so I can plug it into the power steering line? Thanks guys.
Old Mar 21, 2006 | 10:13 AM
SkankyEJ7's Avatar
Default Re: Power Steering Sensor (burningwrek)
expletive it you dont need that pos, i removed my power steeringm, and i have no problems at all
Old Mar 21, 2006 | 11:54 AM
Default Re: Power Steering Sensor (98ekhx)
well I'm still going to use my power steering, So do I still need that sensor for it to function optimally?
Old Mar 21, 2006 | 11:57 AM
the soL that could's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burningwrek &raquo;</TD></TR><TR><TD CLASS="quote">well I'm still going to use my power steering, So do I still need that sensor for it to function optimally?</TD></TR></TABLE>
duh... otherwise it wouldn't be there. is it cut?
Old Mar 21, 2006 | 12:02 PM
Default Re: Power Steering Sensor (the soL that could)
no, I just can't seem to locate the plug on the harness that plugs into the female side on the power steering line. I thought it was on the harness but I can't see it. Everything else is plugged up. Am I just missing it or something? I haven't really been able to go over it thoroughly because the cars at my parents house but I will thursday.
Also, theres a 4 female plug on the injector section of my harness that I'm not sure about what plugged into a little black sensor that was mounted to my fuel rail on the d16y8. anybody know what that is and if I need that on my b20 because its missing on the b20 fuel rail. thanks guys.
Old Mar 26, 2006 | 08:26 AM
As I searched for the sensor to plug into the power steering pressure switch plug, I remembered that my motor is jdm and only the usdm motors came with the power steering pressure switch plug (according to the Haynes Manual). My question is how is this going to affect my power steering? I'm using an obd1 p75 ecu if that helps. I just want my power steering to function correctly.
Old Mar 26, 2006 | 01:37 PM
suspendedHatch's Avatar
It's an idiot switch. If you're not an idiot, and you can handle maintaining your PS fluid level, then you don't need it.
Old Mar 26, 2006 | 02:01 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Power Steering Sensor (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">It's an idiot switch. If you're not an idiot, and you can handle maintaining your PS fluid level, then you don't need it.</TD></TR></TABLE>
INCORRECT. the switch senses movement in the steering, and bumps the idle up accordingly so the motor does not stall under increased drag of the p/s pump.
you do not need the switch hooked up for either the p/s to work or the motor to function. just be warned that at idle, you may have to give it a little throttle when you turn the wheel, otherwise the motor might dip low and stall.
what engine harness did you use?
Old Mar 28, 2006 | 10:08 AM
Default Re: Power Steering Sensor (Rodney)
I used the stock 98 civic ex harness
Old Mar 28, 2006 | 12:07 PM
Rodney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burningwrek &raquo;</TD></TR><TR><TD CLASS="quote">I used the stock 98 civic ex harness</TD></TR></TABLE>
so what happened to the plug for the sensor??
Old Mar 28, 2006 | 12:30 PM
NJcoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney &raquo;</TD></TR><TR><TD CLASS="quote"> INCORRECT. the switch senses movement in the steering, and bumps the idle up accordingly so the motor does not stall under increased drag of the p/s pump.
what engine harness did you use?</TD></TR></TABLE>
Very well stated, and all above information is correct.
Old Mar 28, 2006 | 07:16 PM
well as far as I can tell from the Haynes manual is that the power steering pressure switch connects on the block near the crank fluctuation sensor. I've looked for it and I just can't find the sensor that they're talking about. The sensor isn't part of the harness and I can find it on the block. Several other people helped pull the old motor so I'm guessing that one of them set it down somewhere in the dark abyss that is my parent's garage and I just haven't found it yet.
PS. If I can't find this sensor, will a light weight power steering pulley reduce the drag enough to prevent the engine from stalling?
Old Mar 29, 2006 | 02:55 AM
Rodney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burningwrek &raquo;</TD></TR><TR><TD CLASS="quote">If I can't find this sensor, will a light weight power steering pulley reduce the drag enough to prevent the engine from stalling?</TD></TR></TABLE>
nah, just give the thing some gas... problem solved.
Fred Demara
Jan 4, 2012 04:33 AM
Bradsxx7
Apr 12, 2009 02:36 PM
crackerjacker006
Jul 19, 2005 12:27 PM
sleeper95Lude
Jan 31, 2005 03:29 PM
SweetAzCivic
Mar 19, 2004 08:43 PM
