Rules/Regs: "No Engine Swaps"
Old Mar 21, 2006 | 08:49 AM
billyVR6's Avatar
Default Rules/Regs: "No Engine Swaps"
This is pretty much for any of the sanctioning bodies staff that frequent/read this forum.
With my new project at hand I want to get some stuff cleared up before I go any further. I fully understand "no engine swap" regulations, but how does that translate to your cylinder head?
I have 4 factory cylinder head options. All of which will bolt right onto an existing engine/short block that is available for my chassis direct from the factory. If I do a head swap onto an engine code that is specified for the chassis that I have chosen to race with, will I get turned away and sent off to another class/brackets?
Thanks.
- billy
Old Mar 21, 2006 | 09:39 AM
2008cc's Avatar
Default Re: Rules/Regs: "No Engine Swaps" (billyVR6)
as long as it is a production head i wouldnt think it would be ok. gotta love vw interchangability
Old Mar 21, 2006 | 09:59 AM
E-Town4229's Avatar
Default Re: Rules/Regs: "No Engine Swaps" (2008cc)
which class are you referring to billy? if its street stock i would just gather up all your info and email it to the nhra tech dept.
-Roger
btw are you doing? a 20v 1.8t head on the aba?
Old Mar 21, 2006 | 11:48 AM
billyVR6's Avatar
Default Re: Rules/Regs: "No Engine Swaps" (E-Town4229)
I feel the same way about the production head thing, I just really want to make sure I have everything covered before I get to far into anything at this point.
Roger, I will submit to NHRA, but I am interested in what other sanctioning bodies standard might be. The car will be for the street classes (drag radials) where most of these engine swap rules will apply... BUT I also what it it so it can compete in a pro/amature Comp 4 type of class with making only making a few changes.
Volkswagen does have factory naturally aspirated 20v engines, they just use a 144mm rod in a shorter block. I plan on staying with the ABA/AEG block, the 159mm rods will help keep the the rod ratio a bit more disirable with the crank I am going to have to use.
I just needs this nailed down, this season is on hold as we have a baby coming but still have plans to keep the engine build moving along as best as I can with everything going on.
- billy
Rivera83
Jul 3, 2019 10:30 AM
lucianocivicsi
K Series
Mar 31, 2018 11:41 AM
FairlightRacing
Oct 1, 2007 05:41 AM
Space Boy
Oct 1, 2003 10:49 AM
