How to remove clear coat scratches?
Old Apr 2, 2002 | 12:30 PM
SlyGSR's Avatar
Default How to remove clear coat scratches?
I have a few minor surface scratches on my front bumper that I'm sure would disappear if I had the right tools
What do detailing shops use to do this? I could always try and buff it out (but this only hides the problem..sorta like a wax coat) ....there must be some sort of extremely fine clear coat sandpaper for this purpose?
TIA
SlyGSR
Old Apr 2, 2002 | 12:48 PM
Mr. Thunderlips's Avatar
Default Re: How to remove clear coat scratches? (SlyGSR)
Well, when using a buffing wheel properly with a good compound...it actually removes layers of the clear...but very little. You can always use a very high grit wet sandpaper, but I highly do not reccomend this. You will probably end up sanding too much, and chew right through the clear, and start removing paint. Just get a hold of a wheel and some good compound, or better yet, pay someone to do it for you...like a professional.
slogfilet
Paint and Body
Aug 20, 2014 04:55 PM
dizbjazon
Mar 18, 2009 07:08 AM
v8 integra
May 19, 2008 02:50 PM
snatch
Nov 14, 2005 07:49 AM
