question on wiring up z6 into 97 dx?
hey whats up peoples!
im going to put my z6 into my 97 dx hatch, before someone jumps on the SEARCH IT rampage i have searched and acumilated the best ifo i can but still need to double check my info!
here we go
chassis 97 dx hatch automatic.
motor d16z6 manual.
i already have the obd2a to obd1 jumper, a p28 ecu, clutch line kit, pedal assy,and the full z6 swap!
1. i can use my existing dx engine wiring harnnes correct?
i would have to extend wires that are needed to reach there sensor.
should i use all the sensors from my y7 intake manifold?
do i need to use the iac from the z6 or the y7? i also have a y8 mani too that i can use sensors from! are there any other small sensor related things i should know?
2. i have also the wiring harnness from the z6 , so i can use those plugs to run the vtec wires directly to the jumper?
is there anything else i should know?
i found good threads on how-to auto to manual so im pretty good in tht department!
if you can contribute to this thread it may be informable to someone also in the future!
thanks in advance
Dann
here we go
motor d16z6 manual.
thanks in advance
Dann
Cozmikk
Nov 3, 2017 12:35 PM
