Ticking only in cold weather, even with warm motor.
Old Mar 20, 2006 | 11:44 PM
Toadfart's Avatar
Default Ticking only in cold weather, even with warm motor.
My engine seems to make an odd ticking noise that's speed dependant when the weather is cold. Typically night time or colder days. This is even when the motor is warm. However, when the weather is nice and warm outside or if I drive during the day there is no ticking.
The valve lash was set properly, so the motor does not need a valve adjustment. Any input?
Old Mar 21, 2006 | 10:58 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Ticking only in cold weather, even with warm motor. (Toadfart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toadfart &raquo;</TD></TR><TR><TD CLASS="quote">My engine seems to make an odd ticking noise that's speed dependant when the weather is cold. Typically night time or colder days. This is even when the motor is warm. However, when the weather is nice and warm outside or if I drive during the day there is no ticking.
The valve lash was set properly, so the motor does not need a valve adjustment. Any input?</TD></TR></TABLE>
My friend's GSR did the same thing. He had new valves, valve springs, and retainers installed, and it went away. Hope that helps.
Old Mar 21, 2006 | 12:32 PM
Toadfart's Avatar
Default Re: Ticking only in cold weather, even with warm motor. (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">
My friend's GSR did the same thing. He had new valves, valve springs, and retainers installed, and it went away. Hope that helps.</TD></TR></TABLE>
What do you mean he had? He replaced his valves, springs and retainers?
Old Mar 21, 2006 | 01:47 PM
RobbieG35's Avatar
12 Years Strong
What do you mean he had? He replaced his valves, springs and retainers? </TD></TR></TABLE>
That's right. He installed a Supertech valvetrain and the noise went away.
Old Mar 22, 2006 | 08:48 PM
Jimmy's Avatar
Global Moderator
What weight of oil are you using? Running a really thin oil in cold temperatures could be your problem. Switch to a thicker oil and see if it fixes your problem.
Old Mar 22, 2006 | 09:35 PM
Toadfart's Avatar
Default Re: (Jimmy)
Hmmm good idea. I'm running 10w30 Castrol GTX
ArmaanOG
Dec 28, 2009 01:46 PM
slow_cx
May 11, 2008 11:50 AM
thugstruggle
Jul 12, 2006 12:26 AM
918-Hatch
10
Nov 10, 2004 03:10 PM
Anthrax-VX
Apr 21, 2004 11:07 PM
