Brake help
Old Mar 20, 2006 | 10:40 PM
underrated's Avatar
Default Brake help
Here's the deal, 92 civic hatch w/4 wheel disc, no abs. Everything has been changed which includes: master, booster, front and rear calipers and front brake hoses. THe problem is that after driving around for about 5 minutes the calipers will not release the rotors. If you jack the car up the wheels will not spin. If the car sits for about 5 minutes than it goes back to normal until you decided to drive again.
Anyone have suggestions??
Old Mar 20, 2006 | 10:42 PM
BlueIntegraBoy's Avatar
Default Re: Brake help (underrated)
The calipers are semi-seized?
Old Mar 20, 2006 | 10:50 PM
underrated's Avatar
Default Re: Brake help (BlueIntegraBoy)
even if they are new?
Old Mar 20, 2006 | 10:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underrated &raquo;</TD></TR><TR><TD CLASS="quote">even if they are new?</TD></TR></TABLE>
I guess not. Was the brake system properly bled?
Old Mar 21, 2006 | 12:21 AM
underrated's Avatar
yes they were.
Old Mar 21, 2006 | 12:52 AM
egtwincam's Avatar
check your brake caliper sliding pins if they move freely, they may need to be cleaned and lubed. if good, check your brake lines are not crimped. other than that you may have contaminated brake fluid ..ie engine oil in brake fluid that can cause seals to swell...
Old Mar 21, 2006 | 10:30 PM
underrated's Avatar
Default Re: (egtwincam)
Everything checks out, if you looked at the braking system it looks brand new. Tried again today and still the same problem.
Old Mar 27, 2006 | 06:41 PM
egtwincam's Avatar
OH. check your brake pedal free play. it may need to be adjusted. you probably have no free play and its simulating "riding on the brakes"
hteg12
Jul 18, 2013 05:13 PM
tazz29
Jul 9, 2008 10:52 AM
RedDC5
Feb 22, 2005 06:30 PM
HATCHingMN
Feb 24, 2004 09:17 PM
