Wiring on an Eg Help
Old Mar 20, 2006 | 07:16 PM
95EG2006805's Avatar
Default Wiring on an Eg Help
Can i use a OBD 1 integra ls wiring harness on and OBD 2 B18B for my 95 Eg Swap?
Old Mar 20, 2006 | 08:05 PM
95b16ej1's Avatar
Default Re: Wiring on an Eg Help (95EG2006805)
should be plug and play if you use the OBD1 dizzy and alternator
Old Mar 20, 2006 | 11:48 PM
hatchi's Avatar
you can use either one
Old Mar 21, 2006 | 12:03 AM
fmrprojects's Avatar
Default Re: Wiring on an Eg Help (hatchi)
u need to change the injectors too. just try and get a obd-2 LS harness. it will work better and you dont have to change anything on the motor. just use everything in the engine bay obd 2 and use a obd 1 p75 ecu
amish_assassin88
Dec 11, 2008 08:02 PM
cxjon
Mar 22, 2004 02:46 PM
C1V1C
Apr 17, 2002 05:38 PM
